2 Wire Light Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 07-20-2014, 05:26 AM   #1
2 wire light switch
Hi
I am changing a pull cord light switch to a motion sensor one but after opening the old light switch it only has a black and red wire and the black goes to common on the old pull switch the new sensor has 3 wires how do I wire?
Giles
Giles39 is offline   Reply With Quote
Old 07-20-2014, 05:33 AM   #2
DIY staff
Rewards Points: 7,174
If the third wire that is needed is a neutral---you will need to add a neutral to the box.
Odd set up--pull chain switches are usually part of a light fixture--and a light fixture has a neutral--More info please.
Troubleshoot a 4-way switch circuit: instructions for a 2-year-old pete0403 Electrical 13 11-13-2015 04:14 PM
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 07:25 PM
Light fan burn out, wall switch backwards later LOYD DUNCAN Electrical 1 09-18-2012 06:49 AM
hard wire from light switch and outlet pennyeagle Electrical 0 08-27-2011 01:00 PM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
