2-way Wiring Shortcut? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-13-2013, 12:17 AM   #1
Rewards Points: 452
2-way wiring shortcut?
As a newb, I would have wire nutted all the black wires together, with pigtails going to the light, instead of the way shown here below.
Is my way acceptable too?
I would have never known to wire the hot and neutral and mark it with tape.
pman6 is offline   Reply With Quote
Old 04-13-2013, 12:26 AM   #2
" Euro " electrician
frenchelectrican's Avatar
In old days it used to be like that but not any more and the reason why to remark the white conductor ( only with NM or UF cable ) so you know you have hot supply and black is switched hot during switch loop mode.
I do not know which state you are in but there is a new code it came out sometime back now it will required netural conductor at all the switch box location the reason why due there are some motion sensor or electronic switch will required the netural conductor to order to get that device function properly.
Merci,
Marc
Old 04-13-2013, 06:17 AM   #3
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
If you pigtailed the blacks and went to the light with the tail, the light wouldn't turn off.
Old 04-13-2013, 10:26 AM   #4
joed's Avatar
Rewards Points: 13,740
And if you also pigtailed all the whites to the light the switch would have tripped the breaker when you turned it on.
Old 04-13-2013, 10:51 AM   #5
It is not the color of the wire which is important, rather what each wire is being used for!
In the case of the wires going to a switch, both should be black, but what you have available to use is wire with white and black. So black tape is placed on the white wire (sometimes*) to indicate it is black ("hot").
*This is not always done, but should be done.
A switch switches off the "hot" wire.
How would you connect the wires in the following picture? Answer: It depends on what each wire is being used for!
Billy_Bob is offline   Reply With Quote
Old 04-13-2013, 11:03 AM   #6
Rewards Points: 2,516
Yeah I always laugh when people get to pre-occupied with the color of the insulation on the wire instead of the purpose of the wire.
Electricity does not care what color the insulation is!!!
hammerlane is offline   Reply With Quote
Old 04-13-2013, 11:41 AM   #7
Rewards Points: 31
Merci,
Marc
We always do this in common areas like hallways, public washrooms, storage rooms, Etc...it makes it MUCH easier if the customer decides to use a motion sensor or a timer switch
Olsy is offline   Reply With Quote
Old 04-13-2013, 12:38 PM   #8
Rewards Points: 452
I get it now. I see the path of the circuit.
Old 04-13-2013, 01:08 PM   #9
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Neutral is ALWAYS white, WHITE isn't always neutral!
Old 04-13-2013, 02:19 PM   #10
Banned Electrician
HARRY304E's Avatar
Rewards Points: 204
With one wire nut...
"Government is not the solution to our problem; Government is the problem."
HARRY304E is offline   Reply With Quote
Old 04-13-2013, 07:48 PM   #11
For the USA / Canada side that is correct the netural useally white but over here in France it is bleu for netural but in old days the black was used for netural so it kinda open the eyes when you check out the system.
Merci,
Marc
Old 04-14-2013, 03:48 AM   #12
Rewards Points: 452
one more exercise for me...... adding parallel light to switch loop-
I studied some wiring books, but can't find an exact example.
this ok?
Old 04-14-2013, 06:22 AM   #13
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
this ok?
NO ....
just jump the white and the black from the LIGHT FIXTURE ....to the next light/lights
Philly Master is offline   Reply With Quote
Old 04-14-2013, 06:29 AM   #14
Rewards Points: 214
Originally Posted by Philly Master View Post
NO ....
What is wrong with his diagram doesnt it show the white and black being jumped from the light fixture?
rosem637 is offline   Reply With Quote
Old 04-14-2013, 08:32 AM   #15
Rewards Points: 516
You have 3 wires going to light #2 ...
edit ..oh never mind not enough coffee yet .. i see its the ground sorry .....
Help with wiring issues on a newly purchased house ThatGuy Electrical 13 01-17-2012 10:51 AM
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 09:01 AM
Backyard wiring questions MikeInDetroit Electrical 1 11-02-2011 09:46 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 06:45 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
