2 Way Switches - Electrical - DIY Chatroom Home Improvement Forum
Old 07-08-2011, 03:17 AM   #1
2 way switches
how do i wire 1 light fixture with a 2-way switch
kerry haughey is offline   Reply With Quote
Old 07-08-2011, 07:55 AM   #2
Not sure I understand the question. The switch interupts the hot line side of the light. Hot to one side of switch, the other side of the switch to the light, with neutral and ground supplied to the light.
Old 07-08-2011, 08:15 AM   #3
Rewards Points: 1,570
Perhaps the OP means a 3-way switch (light operated from 2 different switches)?
If so, search this site or google the term; it has been covered multiple times or post your particulars.
bob22 is offline   Reply With Quote
Old 07-08-2011, 08:41 AM   #4
joed's Avatar
Rewards Points: 12,002
There are at least five different configurations that will work. It depends if the power is at the light or one of the swithces. It depends if the switches are one either side or one side of light etc. We need a lot more details.
Here are some of the options.
http://www.selfhelpandmore.com/switc...-way/index.php
Old 07-08-2011, 06:55 PM   #5
dmxtothemax's Avatar
Rewards Points: 5,102
[quote=bob22;681901] (light operated from 2 different switches)?
In Australia this is called a two way switch,
Any idea's why you call this a three way switch ?
To us a three way switch,
would have three switchs,
also possible,
with the correct type of switchs used.
dmxtothemax is offline   Reply With Quote
Old 07-08-2011, 07:15 PM   #6
Semi-Pro Electro-Geek
Rewards Points: 2,900
I think the reason is that there are three possible switch position combinations: both up, both down, or one up and one down (which are equivalent). Thus, there are three "ways" the switches can be flipped.
mpoulton is offline   Reply With Quote
Old 07-08-2011, 08:02 PM   #7
Sounds logical !
Thanks for the repy !
2 Lights & 3 switches, doesn't look right curious1 Electrical 1 10-26-2010 11:26 PM
Question about wiring and voltage with switches and lights rswurth Electrical 17 06-21-2010 12:12 AM
Question about switches on a 20 amp circuit Abs777 Electrical 6 04-28-2010 11:09 AM
Replacing switches turning into nightmare. RyanD Electrical 19 05-26-2009 07:19 PM
Need help replacing switches in four-way circuit magnolia Electrical 3 05-09-2008 10:40 PM
