2 Way Switch Mystery.. No Power At Switch But Power At Light When Turned On - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-27-2011, 08:31 PM   #16
Rewards Points: 198
so is a 3 conductor cable used for 2 breakers used often?
vote4Pedro is offline   Reply With Quote
Old 06-27-2011, 09:20 PM   #17
Semi-Pro Electro-Geek
Rewards Points: 2,922
Yes. This is called a "multi-wire branch circuit" or MWBC. The two breakers must be on different hot legs, so the two hot wires have 240V between them and the neutral wire only carries the difference in current between them. Until recently, two completely separate circuit breakers could be used on a MWBC and there would not necessarily be any indication on the panel that it was wired that way. This led to some safety issues when servicing, since turning off one circuit breaker but not the other would not make it safe to disconnect and work on the neutral conductor. So nowadays the NEC requires that MWBC's be wired only with adjacent circuit breakers that have a the breaker handles tied together so they can only be turned off simultaneously.
mpoulton is offline   Reply With Quote
Old 06-27-2011, 10:13 PM   #18
Rewards Points: 198
so if i want to draw power from one of the hots for a bathroom light/ bathroom fan, can i still use the white as neutral?
Old 06-27-2011, 10:25 PM   #19
Not only can you, you have to. What else would you use?
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
No Power to Light Switch tgoodjr Electrical 8 04-04-2011 05:55 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 09:02 AM
can a power surge flip a light switch? bluebee1314 Electrical 9 07-13-2009 02:33 AM
