Old 11-28-2011, 01:22 PM   #1
2 Wall Lights, 1 Switch
I am replacing a bathroom vanity strip light with 2 wall lights that are controlled by one switch. The wiring for 2 lights was already in place. The set up is as follows -
Hole on left - standard white, black & copper wires
Hole on right - 2 bundles of wires, (white, black, copper) each in it's own sheath.
Switch - 2 bundles of wires, (white & black) each in it's own sheath. The switch is hooked up with a black wire from each sheath. The white wires are capped off.
New light fixtures - 2 lights per fixture, therefore there are 2 white wires & 2 black wires
The hookup -
Left hole is easy - 2 white fixture wires to white - 2 black fixture wires to black - ground to ground
I'm stumped on the right hole. I've feel like I've tried every wire combination and I can't get all 4 lights to work. I'm assuming one of the sheath sets on the right is the 'master' which will control both the left and right lights, but I have no idea which. Could it also be the wiring of the switch?
twak21 is offline   Reply With Quote
Old 11-28-2011, 01:58 PM   #2
Licensed electrician
The box with two cable is simply power coming into and another cable continuing power to the second fixture.
Just make color to color connections. Splice all grounds.
Old 11-28-2011, 02:50 PM   #3
So, the setup of the switch is ok?
Old 11-28-2011, 06:32 PM   #4
joed's Avatar
Switch setup is correct.
At the light connect all the whites together and all the blacks together.
At all boxes connect all the grounds(bare or green wires) together.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 11-28-2011, 07:46 PM   #5
Are you saying connect all 4 whites together, (2 from the light fixture & 2 from the box) and 4 blacks together or are you saying to make 1-to-1 connections, (ex white light fixture wire to white box wire)? I did a 1-to-1 on the right box but that did not light up anything.
Sorry if I'm not grasping the obvious. This is all new to me.
Old 11-28-2011, 07:59 PM   #6
Electrical Contractor
All white wires connect together and all black wires connect to each other.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Trouble with GFCI Outlet + Switch for pool lights kentf Electrical 5 05-23-2011 12:37 PM
Help with Two Switches & Two Lights simplyphp Electrical 36 11-25-2010 03:47 PM
Use factory fog light switch for aftermarket lights? downunder Automotive Repairs 6 07-10-2010 12:45 PM
I'm having trouble replacing a wall switch jamesjames Electrical 6 03-14-2010 03:44 AM
Motion switch wired to two circuits Sibkuz Electrical 2 04-22-2009 08:31 PM
