-   -   2 Wall Lights, 1 Switch (http://www.diychatroom.com/f18/2-wall-lights-1-switch-124881/)
twak21 11-28-2011 12:22 PM
I am replacing a bathroom vanity strip light with 2 wall lights that are controlled by one switch. The wiring for 2 lights was already in place. The set up is as follows -
Hole on left - standard white, black & copper wires
Hole on right - 2 bundles of wires, (white, black, copper) each in it's own sheath.
Switch - 2 bundles of wires, (white & black) each in it's own sheath. The switch is hooked up with a black wire from each sheath. The white wires are capped off.
New light fixtures - 2 lights per fixture, therefore there are 2 white wires & 2 black wires
The hookup -
Left hole is easy - 2 white fixture wires to white - 2 black fixture wires to black - ground to ground
I'm stumped on the right hole. I've feel like I've tried every wire combination and I can't get all 4 lights to work. I'm assuming one of the sheath sets on the right is the 'master' which will control both the left and right lights, but I have no idea which. Could it also be the wiring of the switch?
Jim Port 11-28-2011 12:58 PM
The box with two cable is simply power coming into and another cable continuing power to the second fixture.
Just make color to color connections. Splice all grounds.
twak21 11-28-2011 01:50 PM
So, the setup of the switch is ok?
joed 11-28-2011 05:32 PM
Switch setup is correct.
At the light connect all the whites together and all the blacks together.
At all boxes connect all the grounds(bare or green wires) together.
twak21 11-28-2011 06:46 PM
Are you saying connect all 4 whites together, (2 from the light fixture & 2 from the box) and 4 blacks together or are you saying to make 1-to-1 connections, (ex white light fixture wire to white box wire)? I did a 1-to-1 on the right box but that did not light up anything.
Sorry if I'm not grasping the obvious. This is all new to me.
jbfan 11-28-2011 06:59 PM
All white wires connect together and all black wires connect to each other.
