2 Switches In A 3 Gang Box? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-13-2010, 02:26 PM   #1
2 switches in a 3 gang box?
Are there any problems with putting only 2 switches in a 3-gang box? The main reasons for my doing so is to have extra room to wire and because I only have 3-gang boxes without a trip to the store (again ).
Thanks for your comments!
RedBear is offline   Reply With Quote
Old 01-13-2010, 02:53 PM   #2
You are doing something wrong if you can't put 2 switches in a quad box
I use a dual switch in a single box without any problem
You will have hard time finding a faceplate with 2 switch openings & a blank as the 3rd
You will be stuck buying the modular faceplates
Old 01-13-2010, 02:58 PM   #3
Remodeling Contractor
returning to get the correct box is easier than finding a odd ball plate.
Old 01-13-2010, 04:02 PM   #4
J Calvin Construction
jcalvin's Avatar
Rewards Points: 150
I have seen this solution often. Many people complain about the switch that doesn't control anything until you open it up and see that there is nothing attached to the switch. My best guess was someone done as you are thinking and used a box too big or needed the extra room for a junction box. The best solution is to buy the correct size box. I'm not sure if this is legal and therefore have never done so in the past.
Cal
You hired WHO?
jcalvin is offline   Reply With Quote
Old 01-13-2010, 04:10 PM   #5
I see the problem. I will return! Thanks for saving me some frustration down the road.
Old 01-13-2010, 04:43 PM   #6
Inspector/Instructor
codeone's Avatar
They do make these if you have no other choice.
http://www.kyledesigns.com/product/8...er_Insert.html
They have colors too.
codeone is offline   Reply With Quote
Old 01-13-2010, 08:37 PM   #7
And these are in his house stocked somewhere? The issue was not to have to return to the supply house.
Old 01-13-2010, 09:56 PM   #8
codeone's Avatar
It was just a option, he could go ahead and install what he had if he wanted to and then order from the site. He asked if there were any options.
Dimmer switches brokenknees Electrical 9 11-29-2009 06:59 PM
Replacing switches turning into nightmare. RyanD Electrical 19 05-26-2009 07:19 PM
grounding switches in old work plastic two gang box wkend2 Electrical 3 03-05-2008 01:33 PM
2 gang box to 4 gang box jwn2126 Electrical 2 03-20-2006 11:03 AM
wiring switches in 3 gang box bobo Electrical 2 02-20-2006 11:13 AM
