2 Switch Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 12-18-2012, 04:36 PM   #1
2 switch problem
I just purchased and older home that i had to have them update the electrical panel before i moved in.
My living room has no ceiling light, its hooked to a switch by the door.
There are no single pole switches in the same box , the left one goes to the porch light and the second one goes to im guessing the outlet,
but the second switch has no power as also my outlet has no power
and the porch light switch only tells me its live with my tester when its in the off position if i turn the porch light on with the power on it doesnt light up,
so i was wondering if anybody could lead me to possibly how this is supposed to be wired as im thinking that maybe they connected the wrong wires together or something as there is a little jumper wire in between the switches , thanks
misticwayz is offline   Reply With Quote
Old 12-18-2012, 06:51 PM   #2
TTW
TTW's Avatar
Hard to figure out from your description.
Could you please post a few pictures?
#1 - If you don't know what you're doing - get a licensed electrician!
#2 - If you follow my advice and something bad happens see # 1
Electricity bites hard, and it could be the last thing you feel... Good Luck!
TTW is offline   Reply With Quote
Old 12-18-2012, 07:23 PM   #3
joed's Avatar
Rewards Points: 11,990
You post does not make sense to me.
OK there is no ceiling light
What's hooked to the switch? You have no ceiling light yet it reads like the non existent light is hooked to a switch.
Old 12-18-2012, 08:21 PM   #4
The left switch for the porch light when on doesnt show that theres power but when its switched to off position it shows its live
im not sure if there are 2 terminals or 3 on each of the switches but i know there was the short wire going from one to the other
but there are 3 sets of wire coming into the box as shown in diagram
so im thinking that maybe they wired it wrong in the box because my outlet doesnt work and the switch never shows its live
so was kind of looking for possibly how its supposed to be wired together, if i remember right theres only 2 wires in each also
any help would be appreciated
if someone cant figure out what my pictures show i will open it up tomorrow and take actual pictures
thanks
Old 12-19-2012, 03:01 PM   #5
The 2nd switch controls the outlet , for a lamp, instead of having something mounted in the ceiling
Old 12-21-2012, 02:20 PM   #6
here are pictures
thanks
2 switch problem-img286.jpg   2 switch problem-img287.jpg   2 switch problem-img288.jpg   2 switch problem-img289.jpg
Old 12-21-2012, 02:27 PM   #7
TTW
TTW's Avatar
Looks like power comes in and is wired to the middle, jumpered between the 2 switches. Then power out from each switch to a separate wire.
Looks fine to me, but your outlet and porch getting no power?
What are you using to test for voltage?
Old 12-21-2012, 02:31 PM   #8
a standard double end probe with red lights on it, second switch gets no power ( as outlet doesnt either)
the porch light works just
the left switch for the porch shows nothing unless the porch light is on
Old 12-21-2012, 02:44 PM   #9
should the jumper wire possibly be coming from the left side of the left switch? or switch possibly bad
EDIT---- The left switch reads live when switch is off, turn porch light on and it doesnt show up
Old 12-21-2012, 02:57 PM   #10
Licensed electrician
Rewards Points: 1,240
I suspect a bad switch. The jumper is not the problem as it is providing power to the other switch and is unbroken to the second switch.
Old 12-21-2012, 03:41 PM   #11
i took the jumper off the right switch and hooked to other screw with wire
and turned breaker back on and my outlet had power so must be the switch, even though i dont understand why my tester says no power when my porch light is on.....
Thanks guys wanted to make sure was wired right before i started messing with anything else
Old 12-21-2012, 06:51 PM   #12
joed's Avatar
Two possible issues I see.
1. Is that a wad of tape on the white wires. It should have a good wire nut on it.
2. The black wire that jumpers to the other switch has a lot of exposed copper on it.
Old 12-21-2012, 11:50 PM   #13
" Euro " electrician
frenchelectrican's Avatar
Joed., If ya ran into some of older home like 50's era or before with oringal wiring like that some case they used to solider it. ( common in old days before wirenuts / marettes were common )
That is typical for that era and I do that once a while try to keep the numbers of splice low as possible.
Merci,
Marc
Light Switch Problem akent215 Electrical 3 03-05-2011 03:12 PM
Ceiling Fan and Light Switch Problem desiboy Electrical 3 03-03-2011 01:09 PM
can switch work for two different outlets? jlmran Electrical 8 02-10-2011 01:31 PM
Problem changing light switch grgryl Electrical 14 08-10-2008 02:26 PM
3 way switch problem Rschrei518 Electrical 2 01-04-2008 01:35 AM
