2 Speed Fan To One Speed High - Electrical - DIY Chatroom Home Improvement Forum
Old 05-13-2009, 11:19 AM   #1
2 speed fan to one speed High
Good morning, last night I installed a whole house fan controlled by a timer. I do not want the low speed capability, just on, and off. coming off the motor per the diagram is a black wire labled, HI, and red wire labled low, and a white wire (com). I simply connected black, to black, and white to white, and did not hook up the red. Fan works fine, but now I am wondering...is it on high? Do I need to hook up the red to something? Do I connnect the red and the black together to get high? Anyone?
U-2 Driver is offline   Reply With Quote
Old 05-13-2009, 11:39 AM   #2
DIY = Done Right 1st Time
I would check the manufactures website for an installation guide. Just by what you have described I would say you have it hooked up correctly. Connecting the Red & Black would more than likely damage your unit. It's prbly configured to run on a 2 pole switch.
BowDown is offline   Reply With Quote
Old 05-13-2009, 12:04 PM   #3
thanx! It ran for 4 hours last night, just wanted to make sure that it was on high
Old 05-13-2009, 09:05 PM   #4
If you want to see the differance, disconnect the fan black and connect the fan red to the power black, it should then run on low speed.
hayewe farm is offline   Reply With Quote
Old 05-14-2009, 07:46 PM   #5
Idiot Emeritus
Rewards Points: 1,492
You have it connected correctly. Just make sure that the red lead is insulated, and can't touch anything.
Rob
micromind is offline   Reply With Quote
how to build a single phase induction motor sashman Electrical 3 03-31-2011 07:18 AM
Chain saw Barry J Landscaping & Lawn Care 7 01-28-2009 01:11 AM
Trane XV80 - low speed fan not working oregondean HVAC 4 01-12-2009 12:46 PM
Question about regular & high speed USB's mact60 PC Repairs & Upgrades 3 08-01-2008 05:55 PM
Two Speed Compressors rjordan392 HVAC 2 08-26-2007 01:32 AM
