2 Sets Of Wires To Bathroom Light Fixture - Electrical - DIY Chatroom Home Improvement Forum
Old 04-24-2013, 03:22 PM   #1
2 sets of wires to bathroom light fixture
I am trying to replace both vanity lights in my bathroom. One has one set of wires from the box and the other has two. On the one with 2, I hooked a white from one set to the black of the other and then I hooked the remaining white to the white on the fixture and the remaining black to the black on the fixture. I hooked all 3 grounds together. The first time the lighting fixture with 2 sets of wires were bright and the light with one set were dim and barely on. So I switched which black and white wires were connected on the fixture with 2 sets and this time both sets of lights were dim. I made sure each time that the black and white wires that I connected were from opposite sets. I'm not sure what else to try. Any help would be appreciated!
Mrsbrad is offline   Reply With Quote
Old 04-24-2013, 03:44 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 254
How was it wired when you took the other ones down?
jbfan is online now   Reply With Quote
Old 04-24-2013, 03:47 PM   #3
I was an idiot and didn't take note of that. I have wired other fixtures with no problem so didn't think much of it at the time. Trust me, I learned my lesson.
Old 04-24-2013, 03:48 PM   #4
Licensed electrician
Rewards Points: 1,272
The 2 blks in the wall in the same box are power in and power out. Both of them get spliced to the fixture blacks. Same with the 2 whites splicing to the fixture whites.
You wired the fixtures incorrectly in a series instead of parallel.
Old 04-24-2013, 04:37 PM   #5
Thanks Jim. That did the trick!
Just replaced light fixture, now switch won't turn it off. 3 wires each side gregp1962 Electrical 12 04-16-2013 06:20 PM
Ceiling light fixture wiring eveready Electrical 2 03-10-2013 11:55 AM
Ceiling Light Help - Quiz - 3 sets of wires roundbox52 Electrical 1 03-28-2012 08:08 PM
Bathroom Light fixture installed? Mishap Electrical 2 03-05-2011 02:10 PM
Bathroom Light Fixture with no junction box? shadowman Electrical 2 07-13-2010 07:54 AM
