2 Sets Of Switches Going To A Fan & Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 04-13-2013, 08:23 PM   #1
Question
2 sets of switches going to a Fan & Lights
I want to bring my source to a switch that goes to a fan & another that goes to a light then connect those to another switch that goes to the same Fan & another switch that goes to the same light. Then from these switches go to the Fan & lights. If you could finish the diagram I put below that would be awesome!! Thanks
see attached diagram
2 sets of switches going to a Fan & Lights-3-way-switches-ceiling-fan_help.jpg
westnj77 is offline   Reply With Quote
Old 04-13-2013, 10:54 PM   #2
Rewards Points: 512
Here's my attempt at the cable layout
Old 04-13-2013, 11:10 PM   #3
So you want 2 sets of 3 way switches?
jsbuilders is offline   Reply With Quote
Old 04-14-2013, 10:18 AM   #4
my newer diagram_Is this wrong?
Below I marked up my diagram on wiring 2 sets of 3 way switches to a Fan & Light. I want it controlled separately from 2 different locations. One diagram below is of my idea (not sure if it is correct or smart) another diagram below it is for you to mark up with your idea. I greatly appreciate your help!!
2 sets of switches going to a Fan & Lights-3-way-switches-fan-light_my-diagram_dyi.jpg   2 sets of switches going to a Fan & Lights-3-way-switches-fan-light_dyi.jpg
Old 04-14-2013, 10:27 AM   #5
All you do is run 14-3 from one light switch to the other. Then 14-2 to the light. And repeat for the fan.
Old 04-14-2013, 10:56 AM   #6
Jsbuilders:
So what you said matches my 2nd diagram, so I guess I'm correct with what I drew out. Cool! Thanks
Old 04-14-2013, 01:00 PM   #7
One wire from switches to Fan/Light
I just talked to someone who talked to his electrician friend and he said to run 1 wire from both switches to the Fan & Light. See my 3rd diagram below. Let me know what you think, is this the best way to do it??
2 sets of switches going to a Fan & Lights-3-way-switches-fan-light_my-diagram_dyi_1-wire-fan-light.jpg
Old 04-14-2013, 01:04 PM   #8
Rewards Points: 2,516
Really?? One wire???
hammerlane is offline   Reply With Quote
Old 04-14-2013, 01:11 PM   #9
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
if i am following along correctly he means 1 14/3 instead of 2 14/2's ...
yes ..
BUT >>>> what code cycle are you on ?? 2008 or 2011 ??
Philly Master is offline   Reply With Quote
Old 04-14-2013, 01:14 PM   #10
can you explain
Black wire goes from light switch to light, Red wire goes from Fan switch to Fan. I updated the diagram, please look at the most recent one. Why doesn't it work, can you explain. Thanks!
Old 04-14-2013, 01:17 PM   #11
I think your electrician friend is saying to run a 14-3 from the first switch to the light then run a second 14-3 from the light to the second switch.
Old 04-14-2013, 01:17 PM   #12
Just want to do the smartest efficient way
If both ways work then thats fine, I just want to do it the smartest and most efficient way. If I don't need 2 wires then I would rather use 1. Unless for safety reasons I'm better off using 2 wires from the last set of switches.
Old 04-14-2013, 01:19 PM   #13
Rewards Points: 516
yes 1 14/3 would be the smarter way ....
Old 04-14-2013, 01:20 PM   #14
You must have the common and traveler terminals mis-wired on some of the switches.
Do you know 3-way switches have a usually darker colored terminal referred to as the common and usually two brass colored terminal referred to as the travelers?
Old 04-14-2013, 01:38 PM   #15
Rewards Points: 516
I do not think you are following alone with the thread .... we are speaking of the SWITCH LEGS TO the FAN LIGHT ...NOT switch to switch
How to wire 2 separate single pole switches to 2 separate lights? stangred1997 Electrical 9 03-08-2013 09:34 AM
2 Lights & 3 switches, doesn't look right curious1 Electrical 1 10-26-2010 10:26 PM
Replaced some switches and outlets, now some lights don't work DWooderson Electrical 3 02-02-2010 12:06 PM
move 2 switches new location, replace with 2 for new lights qchawkfan Electrical 3 01-24-2010 11:15 AM
2 lights 2 switches NEW construction cabinjunkie Electrical 8 07-19-2009 01:50 AM
