2 Red Wires To Install A Chandelier - Electrical - DIY Chatroom Home Improvement Forum
Old 08-07-2009, 02:08 PM   #1
2 Red Wires to install a Chandelier
I removed my old chandelier because we got a new one. When I took off the old one it was showing two red wires. I didn't really think about it until I installed the new chandelier and now I'm only getting light that is coming out of my center piece of the my chandelier and other lights don't work.
Is it because of the two red wires, because I thought it had to have a black wire and a white wire coming out.
What should I do, what can I can do. Do I need to have a electrician do something. Thanks for your help.
thatsportsfan is offline   Reply With Quote
Old 08-07-2009, 02:25 PM   #2
DIY = Done Right 1st Time
How many wires did you have coming out all together? What colors?
Sounds like the light fixture has 2 separate lighting modules and you only have 1 wired up. You see this more with ceiling fans. Sometimes they will branch them out so you can run 2 light switches (1 for fan, 1 for lights).
BowDown is offline   Reply With Quote
Old 08-07-2009, 02:27 PM   #3
Well before you remove the fixture again. Check the body of the light and see if there's any switches.. sometimes there's a switch you can turn or toggle to turn on different portions of the light.
Old 08-07-2009, 02:31 PM   #4
Both of them are red.
But you do have a point about there being a switch, I remember my wife telling me about a switch on it while we were trying to install it. Maybe she played around with it and it turned it off. Good point. Thanks for the help, I will check that when I get home and see if that was the problems.
Switch Junction box has 3 sets of 3 wires. Can't get dimmer to work knockout Electrical 14 01-10-2015 10:08 AM
Adding additional outlet. Pigtail four sets of wires? svanhess Electrical 5 07-12-2009 11:27 PM
installing an electrical outlet with 3 sets of wires + ground dsparks Electrical 7 07-08-2009 07:18 PM
Installing a chandelier preciouschristy Electrical 2 07-06-2009 05:35 AM
Two black wires with one white! Please help! ibs325 Electrical 15 11-18-2007 10:38 PM
