2 Prong To 3 Prong - Electrical - DIY Chatroom Home Improvement Forum
Old 02-26-2008, 05:38 PM   #1
2 prong to 3 prong
I am looking for help. Have a house built in the 50's the wire is black with no metal around it and only has two wires. can I use a self grounding 3 prong oulet if it has a metal box. Or should I put gfci outlets on.
bubs is offline   Reply With Quote
Old 02-26-2008, 05:46 PM   #2
Licensed Pro
If the cable is non-metallic (NM), then the metal box is not grounded. Your options are to rewire with grounded NM-B, add a ground wire that runs back to the panel, or add a GFCI receptacle that is labeled "No Equipment Ground". Additional three-prong receptacles may be added, protected by the GFCI, that are similarly labeled. Please note, the GFCI does not add a ground to the receptacles, but does offer an increased degree of safety.
Old 02-26-2008, 05:59 PM   #3
Sparrky
kingsmurf
do NOT put in three prong plugs . . . .if they are not controlled by an GFCI
device or an GFCI breaker . . .which would be definetly less expensive than putting $11.00 plus a pop GFCI devices in a lot of places
you can install a GFCI device at the starting end....if you will . .and have 3 prong plugs DOWNLINE . . .marked as GFCI receptacles
if you are going to attempt to do this work . .which I do NOT recommend
. .please do go get some home wiring books..a few proper tools and study a bit . .you'll really be happy you did
Kingsmurf is offline   Reply With Quote
Old 02-26-2008, 07:40 PM   #4
thank you for your help. My friend has his electrician that works for him coming over to look at it. He told me the same things. thanks agian
Changing 2 Prong To 3 Prong Outlet JAVAMAN Electrical 38 12-02-2012 06:32 AM
Converting to a grounded outlet pdesjardins Electrical 12 01-19-2009 02:55 PM
Replacements for two prong outlets? Tmb9862 Electrical 9 01-10-2007 09:11 AM
Two wire two prong outlets.. kingman43 Electrical 6 01-22-2006 06:37 PM
3 prong 4 prong 240 ranges. K2eoj Electrical 1 11-21-2005 06:39 AM
