2-Pole Breakers For Single Circuits?? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-20-2012, 05:05 PM   #16
Rewards Points: 79
brric...yes, another good reason for me to install the correct SP breakers. Thanks!! RB
sootybuttercup is offline   Reply With Quote
Old 02-20-2012, 05:08 PM   #17
Master Electrician
Rewards Points: 3,874
Originally Posted by sootybuttercup View Post
rrolleston...there are no 3-wire cables going to any of the breakers that I have identified as being "incorrect". All circuits from these breakers I want to change, are going out on separate black wires in separate NMD cables...to lighting and non-split plug circuits. Thanks! RB
"NMD" cables, is this in Canada?
brric is offline   Reply With Quote
Old 02-20-2012, 05:13 PM   #18
I agree with dougp23. I would not assume anything. Even if you think you are 100 percent sure what's going on, that may not be the case. This is really an odd thing to be done if they are simply two seperate circuits. My advice is to at least get an electrician to come in, if only for an hour, just to verify what is actually going on.
hawkeye11 is offline   Reply With Quote
Old 02-20-2012, 05:13 PM   #19
Electrical Contractor
jbfan's Avatar
Rewards Points: 490
Do not remove the ties.
If you are sure they are not mwbc, then replace the breakers with single pole breakers.
I sure would not waste my or my customer money by installing double pole breakers without a reason!
Old 02-20-2012, 05:16 PM   #20
kbsparky's Avatar
NMD cables = Canada.
Many panels up there have larger guts in `em -- 60 and even 80 space panels are common. Leaves plenty of room for them 2 pole breakers ...
-KB
Old 02-20-2012, 05:19 PM   #21
Rewards Points: 79
yes brric...Canada. You don't use that term down south?
Old 02-20-2012, 06:15 PM   #22
Master Electrician
NM-B here in the sticks.
Old 02-21-2012, 05:16 AM   #23
Rewards Points: 79
I'm having an electrician with 30 years experience take a look, and do the work. Thanks for all the comments!! RB
double pole breaker + outlets / x10 BlueBSH Electrical 0 09-09-2010 12:44 PM
2 circuits controlled by 2 breakers harsuwind Electrical 2 08-30-2010 04:36 AM
240V 2 pole 1/2 inch GE breakers? Isaac-1 Electrical 12 02-09-2010 11:21 AM
Can I install tandem breakers to stop my breakers from tripping? sofakng Electrical 1 04-29-2009 01:44 PM
Understanding Circuit Pannel and Single Pole vs. Double Pole circuit brakers grisha_1 Electrical 4 01-31-2009 07:40 AM
