Old 06-05-2011, 11:43 AM   #1
2 pole breaker
is a 2 pole breaker with two handles that are tied together and marked 30a on each side a 30 amp breaker or 60 amp?
waynebo is offline   Reply With Quote
Old 06-05-2011, 12:14 PM   #2
2 pole breaker
2 POLE/30 AMP.
used for 240v loads mainly
Techy is offline   Reply With Quote
Old 06-05-2011, 12:36 PM   #3
Electrician
SD515's Avatar
2 pole breaker
As Techy said, 30A. Each 'leg' is protected individually up to 30 amps, but if one leg exceeds that, the handle tie makes them both shut off.
Kyle
Purpose of 30amp single pole breaker Giles Electrical 5 02-16-2010 10:30 PM
240V 2 pole 1/2 inch GE breakers? Isaac-1 Electrical 12 02-09-2010 12:21 PM
Question on 240v double pole breaker locations rovers1973 Electrical 10 02-14-2009 06:15 AM
Three way light switches and double pole breaker ShawnColes Electrical 6 04-15-2008 09:25 PM
2 pole breaker Unregistered Electrical 3 09-11-2004 12:15 PM
