2 Pendants 1 Switch...is This Correct - Electrical - DIY Chatroom Home Improvement Forum
Old 07-14-2015, 08:36 PM   #1
Renovating My Land Yacht
Rewards Points: 568
2 pendants 1 switch...is this correct
I have a J box in the ceiling with a run out that was supposed to be for one light originally. Switch is wired correctly and this works as of now with one fixture.
I want to add a second light. Both would be controlled by the one switch.
Is the image below correct in how to run the wiring so that I have power to light one and from light one to light 2. I was planning on using the pancake boxes.
forcedreno2012 is offline   Reply With Quote
Old 07-14-2015, 09:09 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 2,920
That will work, however, the boxes are not large for the extra wire.
Pancake boxes can usually on handle one cable.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 07-15-2015, 01:08 PM   #3
samjg1's Avatar
Rewards Points: 110
If the pancake boxes you plan to use are metal, I believe you will need to bond the ground wire to them also.
Also, rather than than using a pancake box for the first appearance after the switch, you might want to use this one. There is more room for wires, and you won't need to bond the ground wire:
http://www.lowes.com/pd_19841-427-71...ng+fixture+box
I'm not a pro, and I'm sure the pro's here can give you more definite information.
samjg1 is offline   Reply With Quote
Old 07-15-2015, 03:34 PM   #4
Rewards Points: 1,758
In the ceiling? Might. Be easier to just use plastic old work octagon boxes, easy to use, plenty of room for connections. Ron
ront02769 is offline   Reply With Quote
Old 07-15-2015, 10:27 PM   #5
Rewards Points: 568
Thanks all, I looked at the pancake boxes this morning and I swear they shrunk overnight. Got the octagon ones, and yes much more room. Done and Dusted whoo hoo.
Changing one switch in a 3 way circuit to a Lutron motion sensing switch watson524 Electrical 26 03-02-2015 03:32 PM
3-way switch on crack! Makes 40 volts mystic_cobra Electrical 15 02-12-2015 08:53 AM
taco sr503-4 switch jmon HVAC 53 11-12-2012 06:26 PM
Adding Light Switch - Outlet - Light > Correct wiring ? westbank Electrical 4 09-15-2012 10:42 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
