-   -   2 outlets sharing a stud and also telephone jack? (http://www.diychatroom.com/f18/2-outlets-sharing-stud-also-telephone-jack-52154/)
LeviDIY 09-01-2009 07:31 PM
3 Attachment(s)
Hello - classic DIYer noobie mistake. Measured only one. And at that, measured the wrong thing. Lucky for me the sheetrock isn't up yet. Let me explain...
Remodeling a kitchen and ripped out all the walls... adding a bank of cabinets to a wall where there was none. Cabinets are ordered, we like the configuration we've chosen. Ripped out the walls, started to hang new sheetrock around after upgrading to GFCI and adding wiring for under cabinet lighting on another wall.
Was measuring this wall (see below) for cutting and receptacle locations when I realized something. There was a receptacle on the bottom right part of the wall near the corner that was closer than 24" to the corner. The cabinet/pantry for that corner will be standard 24" depth. :eek:
I'd rather not cover the "problem" outlet, nor do I want to cut into the pantry cabinet. I'd like to have an outlet over there, just a few inches out to avoid the cabinet.
My concern is that on the next stud over, there is already a receptacle on the opposite side of the wall. That receptacle feeds the one I need to move. The one I need to move has 2 other feeds out of it.
Concerns/Questions:
1) Can 2 receptacles share a stud? If so, what distance to the J-boxes need to be separated? In other words, can they be "stacked" on top of each other with little distance between them? Or is there a minimum separation required in the wall?
2) I doubt the other lines have enough slack in them to pull to the new stud.... what are my options here? One line runs into a finished room... can I pigtail in the old j-box, cover with a plate, and cut an access hole in the cabinet just in case?
3) The telephone jack a bit higher up on the wall is in the same problem (I don't use it, but it is the main access in the condo, so don't want to permanently hide it).... can I move that easily? I've never worked with telephone wiring, so just want to know if I can touch it... or if not, how to do that safely... or call Verizon?
The pictures should explain in detail... the Red lines with arrow/directions show the flow of the lines. The green lines with arrows/directions are thoughts/what I'd like to do.
Attachment 13205
Detail of outlets:
Attachment 13206
Detail of telephone jack (there is plastic PVC covering supply lines... assuming it can flex over to the other stud):
Attachment 13207
Let me know if you need clarification... thanks! :thumbsup:
220/221 09-01-2009 07:44 PM
Put it anywhere it will fit. Back to back if you want.
2) can I pigtail in the old j-box, cover with a plate, and cut an access hole in the cabinet just in case?
Yes
Yes.
LeviDIY 09-01-2009 07:48 PM
Thanks for the quick response... just want to be sure... I can "stack" it above the one facing the opposite wall and bend the wires coming in the j-box around?
Also... telephone wire... avoiding shock?
220/221 09-01-2009 07:51 PM
Don't put it in your mouth and you will be fine. :laughing:
Telco is "low voltage".
LeviDIY 09-01-2009 08:46 PM
Thank you... much obliged.
Gary in WA 09-01-2009 10:37 PM
Just a same vein question for sparky - don't you get static over the phone from the close proximity (6") to live wires?
Be safe, G
220/221 09-01-2009 11:07 PM
No static from AC to telco.
theatretch85 09-01-2009 11:28 PM
Ah, last I checked, the ringer voltage is 96 volts AC. It gives quite a tickle if your working on the wires when a phone call comes in; word of advice (from someone who's been there done that) leave a phone off the hook if you are concerned about someone potentially calling you while you happen to be moving the phone jack.
Otherwise, if you feel lucky and can do the work without a call coming in, the wires will be ok to work on (that is until someone calls).
If you don't plan on doing anything with the wiring and just physically moving the box from one stud to the other then you should be fine.
frenchelectrican 09-01-2009 11:52 PM
You are pretty close most are useally about 90 to 100 Volts AC but very low HZ range useally about 25 HZ during the ring time but watch out some out of the woods in deep in country don't be suprised they can boost the voltage much as 125 V AC during the ring peroid due the distance but with modern stuff in there it will be more constant voltage now.
Merci,Marc
LeviDIY 09-02-2009 09:24 AM
Much appreciated replies about the phone line... I don't even have a number attached to it (have the cable company's phone deal), so I *hope* that means no phone calls! :)
I will move the receptacles and phone jack tonight most probably... one more question... notice how below and above the phone jack there is PVC conduit? If I move the jack and that conduit isn't "enough" to cover the extra distance... is that a problem?
