2 New Appliances - Electrical - DIY Chatroom Home Improvement Forum
Old 07-31-2012, 12:19 PM   #1
2 new appliances
Hi I currently have a new stove and a new water heater both waiting to be installed, both are currently gas, I know what size wire and everything my question is, will I have enough power to run them both from my inside breaker box which is only rated for 100amps.
As of now I have 1) 30 amp double pole for the dryer 4) 20 amp single pole breakers (washer, microwave, 2 kitchen circuits) and 4) 15 amp single pole breakers for lights and plugs throughout the house
I have exactly enough room for the two double pole breakers I need to add, which is a 25 amp and a 40 amp but I'm worried about my main breaker will it handle it all? I'm sure it would as long as I'm not cooking and doing laundry but I don't want to worry about that.
I could take one of the circuits outside where I have a 200 amp service, but its a much further pull and I would really like to reserve my 1 remaining spot outside for a future shed.
Thanks for the help
smcdonald001 is offline   Reply With Quote
Old 07-31-2012, 01:10 PM   #2
Master Electrician
You would have to do a full load calc but you should be fine with 100a service.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Deodorizing smelly appliances STL B. Appliances 6 07-19-2012 05:02 PM
Storing Appliances in Unconditioned Space Pittsville Appliances 2 01-05-2012 09:02 PM
Using the correct fuses in appliances? razorcut Electrical 2 06-11-2011 09:38 AM
New stainless appliances poolecw Appliances 2 12-04-2008 02:23 PM
Are European appliances really that much better? home_improver Appliances 2 09-30-2008 06:06 PM
