2 Neutrals And 1 Hot Wire? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-15-2012, 05:54 PM   #16
Master Electrician
looks like a commercial/new construction guy brought home some spare parts lol. Yellow wire is use mostly for 347/600v applications around these parts. Easier to identify stuff when the red black blue is 120v and the orange brown yellow is 347/600
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 07-15-2012, 05:57 PM   #17
Mad Scientist
Either that or he's in Chicago.
McSteve is offline   Reply With Quote
Old 07-15-2012, 06:00 PM   #18
Originally Posted by McSteve View Post
Looks to me like it's in condut; the yellow wire is a hot passing through, the white is the neutral, also passing through after stopping at the receptacle, and the black is a hot dedicated to that receptacle.
Also if you look closely at the first photo, there is a black wire passing straight through. The outlet in the living room (just on the other side of the wall) that is part of the same circuit does not have the yellow wire.
brad34 is offline   Reply With Quote
Old 07-15-2012, 06:01 PM   #19
Minnesota
Old 07-15-2012, 06:18 PM   #20
GFCI and ground.
Originally Posted by CopperClad View Post
I'm not an electrician. But can you hook up a GFCI without a ground?
Yes, you can install a GFCI without a ground. This is one way that the code allows a two prong (ungrounded) outlet to be substituted with a three pronged outlet...by the use of a GFCI outlet recepticle. If there is a ground short, the current to ground is limited by the GFCI to 6 milliamps. (A lot less than would flow if the same short were to happen on a non GFCI circuit even with a ground.
kontoose is offline   Reply With Quote
Old 07-15-2012, 06:22 PM   #21
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
deleted...
Old 07-15-2012, 06:27 PM   #22
Note. The ground screw, by code, ought to be screwed into a threaded hole in the junction box - (10/32 is the usual size), and the screw needs to be slotted, and hex. head driven, and colored green. Self drilling "tek" screws, or self tappers are not accepted as ground "pigtail attachment.
Old 07-15-2012, 06:29 PM   #23
E2 Electrician
Code reference?
Old 07-15-2012, 10:51 PM   #24
Ground Screw.
Originally Posted by stickboy1375 View Post
Code reference?
250...and a smidgen. (Look it up, Maynard).
Old 07-16-2012, 05:06 AM   #25
E2 Electrician
I don't get it?
Need to know if my grounds and neutrals are connected right dorlow Electrical 185 01-15-2012 02:54 PM
Help! Glowing spot at bonding screw WillK Electrical 85 12-16-2011 08:22 AM
4 wire cable configurations rjniles Electrical 6 10-05-2011 03:35 PM
old wire, backfed switch question Jack A. Trades Electrical 6 07-03-2008 11:05 AM
Replacing light killed downstream outlets, totally stuck amissner Electrical 5 07-13-2006 06:02 AM
