2 Main Breakers, One Meter - Electrical - DIY Chatroom Home Improvement Forum
Old 04-18-2009, 12:46 AM   #1
2 main breakers, one meter
the duplex has been converted to a single family residence, the new addition of the house uses one panel, the original panel left unchanged. currently there is 1 meter left, but 2 100amp main breakers, one connected, one not. can I connect both 100amp main breakers to the meter to get 200amp service?
jacky12b is offline   Reply With Quote
Old 04-18-2009, 08:04 AM   #2
Rewards Points: 150
Send a message via AIM to Bocolo
I am not an electrician but from what I understand only an installation from the power company will give you 200 amps not the combination of 2 100 amps panels. I don't think you can have two main panels with just one meter. You can have a main panel and a sub panel. But from what I understand you can not just connect them to each other. There are grounding and bonding issues which I am not 100% informed on and still trying to learn. Also, I don't know if you do the main panel and subpanel approach if your sub panel is allowed to have the same 100 amp breaker as your main panel. I am thinking the breaker should be smaller. I am sure you will get your answers soon you have a lot of pretty smart guys in here.
One Pound of Knowledge Requires Ten Pounds of Common Sense In Order To Be Useful
Bocolo is offline   Reply With Quote
Old 04-18-2009, 09:00 AM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
You can have two mains off one meter. In fact you have up to six.
To do what you want it would be a lot easier to simply do a 200A upgrade.
To keep the two panels you will still need to replace the double 100A meter pan with a single 200. Then you would have to work a splice box or trough into the service entrance to split the 200 into two 100's. I don;t think you'll find a residential 200A meter pan capable of dual load lugs. You CANNOT tap two SE cables onto the single lugs of a meter pan.
Old 04-18-2009, 09:37 AM   #4
Rewards Points: 150
Thanks for the lesson. Learned something new today.
Pushmatic Panel, no main, no 2.p. breakers avery2008 Electrical 8 05-02-2009 03:51 PM
Water meter aggravations Ultrarunner2017 Plumbing 8 03-21-2009 07:53 AM
Dual Main Breakers dcwestcott Electrical 3 02-23-2009 08:26 PM
Running new Main supply from Meter PEX or PVC? twilightcall Plumbing 7 08-03-2008 08:00 AM
Turning main power supply off from the meter amakarevic Electrical 2 05-22-2007 11:33 PM
