2 Lights, 4 3-way Switches - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-06-2014, 11:20 AM   #16
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Originally Posted by dgfit View Post
Wouldn't I have the same problem with my original configuration - the neutral for two travelers would be in a separate cable. That might be the kicker for running an additional cable from the top switch to the bottom light.
I'm failing to see why you want to bring the switch leg 14/2 from the sw2 location to serve the bottom light.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 01-06-2014, 11:23 AM   #17
Electrical Contractor
jbfan's Avatar
Rewards Points: 490
WB Stubbie.
Good to see with the original name also!
Old 01-06-2014, 11:24 AM   #18
UAW SKILLED TRADES
Stubbie's Avatar
Glad to be back , just trying to stay warm today, -8F at the moment ...
Stubbie
The Following User Says Thank You to Stubbie For This Useful Post:
jbfan (01-06-2014)
Old 01-06-2014, 11:53 AM   #19
UAW SKILLED TRADES
Stubbie's Avatar
The "return power" would be from the top switch and then spliced to the cable from the bottom box to the bottom light.
My point is instead of switched power from the top 3 way ... take constant power to the top 3 way and connect the switched power of the 14/2 ( to the bottom light ) to the bottom 3 way common screw. Same thing just cleaner IMO.
Stubbie
Old 01-06-2014, 12:26 PM   #20
Rewards Points: 278
Ah I see. I did the below three drawings before seeing your post and think I arrived at the same conclusion. I trust the "O" in the "IMO", but am curious what makes it cleaner to you.
Below are what I think are the configurations to consider. The biggest question to me now is whether or not it is ok code wise not having a neutral in the cable with the hots. I also wonder if I am worrying too much about trying to save one cable .
dgfit is offline   Reply With Quote
Old 01-06-2014, 12:53 PM   #21
UAW SKILLED TRADES
Stubbie's Avatar
Cleaner may not be the best term to use. That usually means less wires and wirenuts. I should say I think it will make more sense later or to someone else to see the switched hot in the cable to the light connected to the 3 way switch at the bottom switch location and the power going to sw2 location and the white and red in the 14/3 will be used as travelers. This keeps all blacks in the wirenut and black to the 3 way switch common.. Again just my opinion.
Stubbie
dgfit (01-06-2014)
Old 01-06-2014, 02:22 PM   #22
joed's Avatar
Rewards Points: 12,924
No because each switch has its own power and return in one cable. You are not splitting the use of the wires across two switches. They are wired independent.
The Following User Says Thank You to joed For This Useful Post:
dgfit (01-06-2014)
Old 01-06-2014, 03:12 PM   #23
Licensed electrician
Rewards Points: 1,634
I prefer option 3.
Old 01-06-2014, 03:22 PM   #24
Rewards Points: 278
Originally Posted by Jim Port View Post
I prefer option 3.
I agree after having diagramed it - but with a couple of slight variations shown below to have the neutrals carried separately.
Last edited by dgfit; 01-06-2014 at 03:23 PM. Reason: Clarrified statement about separate neutrals.
Old 01-06-2014, 03:25 PM   #25
UAW SKILLED TRADES
Stubbie's Avatar
I like that also Jim but I thought the implication was difficulty in the switch leg routing from SW2 to the bottom light. In the end I guess it could be either way.
Stubbie
Old 01-06-2014, 03:43 PM   #26
Rewards Points: 278
Honestly, I was just trying to save cable, but the cost of that one run isn't worth the complexity for the next guy to figure it out.
But it was an interesting consideration
two switches, two lights, one box bfan781 Electrical 10 04-13-2015 12:26 AM
Help with Two Switches & Two Lights simplyphp Electrical 36 11-25-2010 02:47 PM
2 Lights & 3 switches, doesn't look right curious1 Electrical 1 10-26-2010 10:26 PM
2 lights 2 switches NEW construction cabinjunkie Electrical 8 07-19-2009 01:50 AM
2 switches, 2 lights, one 14/3? sstrick500 Electrical 2 06-22-2009 07:01 AM
