2 Lights, 4 3-way Switches - Electrical - DIY Chatroom Home Improvement Forum
Old 01-05-2014, 10:08 PM   #1
Rewards Points: 260
2 lights, 4 3-way switches
Light at top and bottom of stairs.
Two switches at bottom of stairs (one switch for light at bottom of stairs and one for light at top of stairs)
Two switches at top of stairs (one switch for light at bottom of stairs and one for light at top of stairs)
Is it code compliant (2000 cycle) to do the following?
Bring power into box at bottom of stairs with 14/2 to feed both switches and provide a neutral
Run two 14/3 cables from bottom switch box to top switch box used as follows:
Cable 1 carries two travelers for one set of switches and a neutral
Cable 2 carries two travelers for the other set of switches, but repurpose the white wire (marked with black tape) to bring switched power from top switch back to bottom box
Run two 14/2 cables as follows:
Cable 1 from top switch box to top light (neutral and switched power from one top switch)
Cable 2 from bottom switch box to bottom light (neutral and switched power from other top switch via repurposed white wire)
This would give me a neutral in both switch boxes and both lights, and I think is the minimum number of NM cables. Would this create any problems with false AFCI trips?
Are there any better ways to do this?
dgfit is offline   Reply With Quote
Old 01-05-2014, 10:13 PM   #2
Rewards Points: 260
Oops - I meant 2011 code cycle
Old 01-05-2014, 10:28 PM   #3
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I can't see anything wrong with it.
The Following User Says Thank You to k_buz For This Useful Post:
dgfit (01-05-2014)
Old 01-06-2014, 05:40 AM   #4
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
or 2 ......14/4 wires ... or 14/2/2 which ever is available locally
http://www.homedepot.com/p/Southwire...255/203641719#
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
The Following User Says Thank You to Philly Master For This Useful Post:
dgfit (01-06-2014)
Old 01-06-2014, 08:11 AM   #5
Rewards Points: 260
If I were to use 14/4, wouldn't I just use 1 14/4 and a 14/2?
The 14/4 cable would be the 4 travelers (with the white wire repurposed)
The 14/2 cable would be neutral and return switched power
Old 01-06-2014, 08:28 AM   #6
joed's Avatar
Rewards Points: 12,002
You are fine except for one thing. Use the remarked white as a traveller instead of return power.
The Following User Says Thank You to joed For This Useful Post:
dgfit (01-06-2014)
Old 01-06-2014, 09:15 AM   #7
jbfan's Avatar
Rewards Points: 240
Why return power?
Run 14/2 from top switch to each fixture.
This eliminates having to remark or re-purpose any wire.
jbfan is online now   Reply With Quote
Old 01-06-2014, 09:41 AM   #8
Rewards Points: 260
Originally Posted by jbfan
Why return power? Run 14/2 from top switch to each fixture. This eliminates having to remark or re-purpose any wire.
I could, and may still do that. It just means I would have one of two configurations between switch boxes that would result three cables instead of two, and also either an unused wire or (still) a repurposed wire:
Configuration 1:
14/3 carrying two travelers and a neutral
14/3 carrying two travelers and an unused white wire (or run it as a "parallel neutral")
14/2 from top box past bottom box to bottom light (with neutral and switched power)
Configuration 2:
14/2 carrying two travelers (with white wire repurposed)
The bottom line is 5 conductors are required between switch boxes and there is no such thing as a 14/5 cable. I agree it would be least confusing to others to go with configuration 1 but it just seems wasteful to have an unused wire, or silly to have two wires run between the two boxes and simply connect them together in each box.
Old 01-06-2014, 09:44 AM   #9
Rewards Points: 260
The "return power" would be from the top switch and then spliced to the cable from the bottom box to the bottom light.
Old 01-06-2014, 10:04 AM   #10
Rewards Points: 4,792
Assuming you are on a 15 amp circuit.
jeffnc is offline   Reply With Quote
Old 01-06-2014, 10:17 AM   #11
Licensed electrician
Rewards Points: 1,266
The simplest way to provide a neutral at each box is to bring power into SW1 on a xx-2. Then run a xx-3 between SW1 and SW2. From SW2 to fixtures on a xx-2. The white stays as a neutral throughout.
Old 01-06-2014, 10:34 AM   #12
joed's Avatar
14/4 is not that easy to find.
It wouldn't be code since neutral and hots are not in the same cable/raceway.
Old 01-06-2014, 10:55 AM   #13
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Why aren't we just using one conductor in a 14/3 to carry constant power to a 3 way at the sw2 location and the other 14/3 to carry the neutral to the sw2 location? Then you can connect a fixture 14/2 to a top 3 way and a fixture 14/2 to a bottom 3 way.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 01-06-2014, 11:21 AM   #14
Rewards Points: 260
If you draw out all of the configurations discussed and tag each conductor you will find the configuration I propose at the start uses fewer cables than all the others discussed. That is not my only consideration and I may still run an extra cable for the sake of simplicity.
The key items not considered in several of the other posts:
1 - there are two three way switches in each box
2 - the route from the top switch to the bottom light runs past the bottom box.
Old 01-06-2014, 11:23 AM   #15
Rewards Points: 260
Originally Posted by joed
14/4 is not that easy to find. It wouldn't be code since neutral and hots are not in the same cable/raceway.
Wouldn't I have the same problem with my original configuration - the neutral for two travelers would be in a separate cable. That might be the kicker for running an additional cable from the top switch to the bottom light.
two switches, two lights, one box bfan781 Electrical 10 04-13-2015 01:26 AM
Help with Two Switches & Two Lights simplyphp Electrical 36 11-25-2010 03:47 PM
2 Lights & 3 switches, doesn't look right curious1 Electrical 1 10-26-2010 11:26 PM
2 lights 2 switches NEW construction cabinjunkie Electrical 8 07-19-2009 02:50 AM
2 switches, 2 lights, one 14/3? sstrick500 Electrical 2 06-22-2009 08:01 AM
