2 Lights 2 Switches NEW Construction - Electrical - DIY Chatroom Home Improvement Forum
Old 07-16-2009, 03:33 AM   #1
Question
2 lights 2 switches NEW construction
Hello Experts (and other DIY's):
I am wiring a new garage and have a pretty basic question that I cannot find the answer to, even in all my "beginner electrical" books.
On one circuit I have 2 lights. These are supposed to be independent lights and switches... BUT... right now switch number one (and light) have to be on for switch number two to work.
What I WANT is for switch 1 to control only light one. And switch 2 to control only light two.
Make sense???
Please help!
BOB
cabinjunkie is offline   Reply With Quote
Old 07-16-2009, 05:11 AM   #2
Remodeling Contractor
you need to bring power (the hot and neutral) to each switch. Run a wire from a power source to the first switch and then the next switch. Then from each switch run another wire to the light you want that switch to control. Tie the blacks to the switch terminals and splice the whites.
Old 07-16-2009, 09:12 AM   #3
joed's Avatar
Rewards Points: 11,516
We need a lot more info to tell you where you went wrong.
Are the switches in the same box?
If not in the same box, what cables are run between boxes and how are they connected to each other, the switches, the fixtures?
If in the same box same question, how are the wires connected?
Old 07-16-2009, 09:48 AM   #4
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Joe is right any advice at this point (given your instructions) would be a shot in the dark). We need to know how your existing wiring configuration is installed.
Answer Joes questions and this will be an easy fix.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 07-16-2009, 02:03 PM   #5
Answers to Joe's questions
Yes they are in the same box.
Incoming wire is hooked to switch and outgoing hooked to switch (black to black, white to white and ground to ground) then carries on to light. Then light from light runs back down to second switch.
Second switch is wired liked the first, except no wires leave last light.
Hope I answered the questions.
Old 07-16-2009, 02:58 PM   #6
joed's Avatar
You need a three wire cable from the first switch to the first light.
Old 07-16-2009, 04:39 PM   #7
UAW SKILLED TRADES
Stubbie's Avatar
A second way to look at the diagram of Joes...take your pick both show the same thing only mines better......
Stubbie
Old 07-19-2009, 12:53 AM   #8
Wire size??
Thanks for the diagrams... I will not get into which one I think is prettier... they were both helpful
I just need to make sure I got this right.... I am running 14/2 from my panel and in the example above, I run 14/3 from switch one to light one and then 14/2 from light one to switch 2 and 14/2 from switch 2 to light 2???
Where else would I need to run 3 wire???
Old 07-19-2009, 02:50 AM   #9
I'm confused.
How many cables are in the switch box.
220/221 is offline   Reply With Quote
Two Lights - Two Switches - One CCT whirly Electrical 14 07-14-2011 08:42 AM
Multiple lights and switches on one circuit Straightgrain Electrical 5 03-31-2009 08:34 AM
Wiring diagram for lights with two switches Ed M Electrical 7 08-10-2008 09:59 AM
3 switches 1 light. need 2 lights 2 switches. Im desprete s richards Electrical 6 07-19-2008 04:18 PM
Overhead lighting Run to lights first then switches, 14/3 to both switches? twilightcall Electrical 4 07-10-2008 05:18 PM
