2 Lights, 1 Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 05-07-2009, 08:14 PM   #1
2 lights, 1 switch
Hi everyone. I am remodeling my basement, there are two light fixtures in the ceiling controlled by one switch. How do I separate the lights and add a new switch to control them seperately?
Thanks in advance
RedWingHockey is offline   Reply With Quote
Old 05-07-2009, 08:21 PM   #2
joed's Avatar
Rewards Points: 11,576
It depends on how they are currently wired. Tell how the wires run at each light and the switch. Tell us where the poewr comes in.
Old 05-07-2009, 08:32 PM   #3
Thanks for the reply joed. The best I can tell, the wires come from the switch to the first light, then there are wire nuts connecting the wires to the next ligh fixture. I cant tell for sure if the wires to the switch are dedicated to that switch, or come from another outlet/switch? (if thats even possible?) I would like to add a switch for the second light, but I'm not sure how to do that.
Old 05-07-2009, 08:36 PM   #4
Smile
desired: separate control for ea. light fixt.
[Assuming], There is a junction box on the ceiling? In that box there are Two Black wires (for each light fixture) connected to the return [wire] of the switch. Separate one wire and connect it to the return wire of the new switch. Or, you can eliminate the original (2 wire) switch cable (Romex or AC/BX) and run a 3 wire cable instead!!!
spark plug is offline   Reply With Quote
Old 05-08-2009, 03:16 PM   #5
joed's Avatar
Where do you want the swtich for the second light? In the same box as the first switch or at a second location?
Wiring Outlets Then Switch Then Lights heydj Electrical 9 05-07-2009 09:09 PM
HowTo: Adding two exterior lights + switch, piggyback new switch off existing switch? ghost Electrical 14 04-19-2009 06:04 PM
2 lights one switch, power to the switch . . . gregoryc Electrical 15 03-17-2009 11:46 PM
Wire Multiple Lights controlled by 4-way Switch? mfleming Electrical 17 11-20-2008 09:46 AM
How to switch fluorescent lights Carissa Electrical 3 08-16-2008 03:28 PM
