2 Lights, 1 Source - Electrical - DIY Chatroom Home Improvement Forum
Old 02-12-2008, 04:46 PM   #1
2 lights, 1 source
please help with basic wiring.....i have 2 florescent lights, wries coming from each.......and 1 power source......please help....thanks!
sportstwe is offline   Reply With Quote
Old 02-12-2008, 04:49 PM   #2
Licensed Pro
It would help if we knew what you wanted to do.
Old 02-12-2008, 04:52 PM   #3
i'll explain......
power both lights from 1 source.........the source is a receptacle.....going to use plug end instead of hard wire....thanks
Old 02-12-2008, 05:47 PM   #4
joed's Avatar
Rewards Points: 12,362
Do you want a switch to control them? Are you saying you need a receptacle to plug them in? Do you want them both switched on together or separate?
Old 02-12-2008, 06:49 PM   #5
two seperate lights with 14/2 coming from both to a box.....then 1 14/2 with a plug on the end.....which will be plugged into a near-by receptacle.....my question deals with connecting the wires.........do i connect all 3 blacks together and all three whites?
Old 02-12-2008, 07:48 PM   #6
I still need help with what I thought would be a simple problem for a professional in the electrical field.....am I barking up the wrong tree?
Old 02-13-2008, 06:10 AM   #7
waiting for spring
arichard21's Avatar
Rewards Points: 150
Sportstwe, you can't add a plug if it is NM (romex) cable. Is this the case?
arichard21 is offline   Reply With Quote
Old 02-13-2008, 11:22 AM   #8
Electrician's Helper
Pudge565's Avatar
Rewards Points: 150
Send a message via AIM to Pudge565
we could help you if you didnt confuse us.
Pudge565 is offline   Reply With Quote
Old 02-13-2008, 08:20 PM   #9
joed's Avatar
You are NOT permitted to use 14/2 NMB as an extention cord witht plug on the end.
Old 02-14-2008, 06:01 AM   #10
waiting for spring
arichard21's Avatar
Rewards Points: 150
300.4 PROTECTION AGAINST PHYSICAL DAMAGE. Where subject to physical damage, conductors shall be protected.
Old 02-14-2008, 08:13 AM   #11
electrician
Not saying anything about if you should do this according to the NEC, but the answer is yes. 3 blacks together, 3 whites together.
And by the way .............. 3 grounds together!
Silk is offline   Reply With Quote
Old 02-14-2008, 09:25 AM   #12
waiting for spring
arichard21's Avatar
Rewards Points: 150
I can't seem to find it, but any cord and plug device has to be stranded wire. NO NM ALLOWED.
undercabinet puck lights ccalmonte Electrical 7 08-05-2008 08:25 PM
help with christmas lights!!!!! reds_21 Electrical 11 11-28-2007 10:02 AM
Porch lights with timer or photocell? ciera Electrical 4 10-29-2007 07:35 AM
Formula for changing lights to recessed bulbs? Jemo Electrical 12 01-26-2007 05:02 PM
power source for recessed lights Jackman Electrical 1 09-18-2006 07:30 PM
