2 Lights, 1 Circuit, Seperate Switches? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-02-2012, 05:42 PM   #1
2 lights, 1 circuit, seperate switches?
i have 2 lights in my living/dinning room, but both lights are on the same switch. i would like to have the lights independant as it is not always the best to have both lights on all the time.
there is only a live and switched live going into the wall switch (2 wires)
is there any way atall i could control these 2 lights independantly of each other??
cheers
ryanreed is offline   Reply With Quote
Old 08-02-2012, 05:46 PM   #2
Not without some rewiring. From your description I can only assume that the lights are daisy chained (the second lights is fed directly from the first). Is there an attic above this room?
Calc is offline   Reply With Quote
Old 08-02-2012, 05:47 PM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
cheers
Only if it was previously wired like the way you would want it to operate. Which doesn't sound like it is.
Old 08-02-2012, 06:03 PM   #4
no way of getting into the ceiling to re-wire lights, as it is on the ground floor with weyroc boards upstairs. are there any remote gadgets that can be wired in to a light to enable it to be operated from a remote?
Old 08-02-2012, 06:08 PM   #5
Yes, there are a lot of different devices that can help you. I've never actually used them so I can't recommend anything but I know they are out there.
As far as your original idea of hardwiring it, depending on the exact positions of the lights, you may be able to rewire the second light with a few small holes to patch. You don't happen to have crown molding in this room, do you?
Old 08-02-2012, 06:28 PM   #6
E2 Electrician
If you don't, would you like some? LOL....
The Following User Says Thank You to stickboy1375 For This Useful Post:
Calc (08-02-2012)
Arcing between circuit breakers and flickering lights mscotter Electrical 12 07-13-2012 01:46 AM
Dimming lights on one circuit, GFCI breaker tripped boatman537 Electrical 4 06-05-2012 11:43 AM
Help with Two Switches & Two Lights simplyphp Electrical 36 11-25-2010 03:47 PM
2 Lights & 3 switches, doesn't look right curious1 Electrical 1 10-26-2010 11:26 PM
Adding lights to a circuit.. Pl check circuit aw44 Electrical 4 08-27-2008 03:09 PM
