2 Hots No Netural - Electrical - DIY Chatroom Home Improvement Forum
Old 02-28-2013, 10:16 PM   #1
2 hots no netural
I'm going to put in a ceiling fan with lights in my living room. In the light switch box the 2 wires coming up into the box are hot. The 2 wires in the ceiling one is hot coming in from the opposite direction than the switch the other dead (its not hooked up at the switch.) Its the old knob and single wire. I'm not sure what I want to do with this. any suggestions???
bjohnson1325 is offline   Reply With Quote
Old 02-28-2013, 10:22 PM   #2
Rewards Points: 30
What are you using to check for voltage, a meter or a non-contact tester?
daveb1 is offline   Reply With Quote
Old 02-28-2013, 10:25 PM   #3
its a generic 120v-240v test light
Old 02-28-2013, 10:28 PM   #4
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
If its knob and tube, there would be no ground present. What are you putting the leads to get a reading?
Old 02-28-2013, 10:30 PM   #5
im using an extension cord putting one lead in the neutral the other to the wire to be tested.
Old 02-28-2013, 10:33 PM   #6
k_buz's Avatar
Your OP is a little unclear. Are you saying that there should be two switches that control this fixture box?
Old 02-28-2013, 10:42 PM   #7
there may have been at one time but im only going to put 1 switch in.
Old 02-28-2013, 10:47 PM   #8
dmxtothemax's Avatar
Rewards Points: 5,202
Most likely the two wires at the light are neutral (dead one),
and the other is the switched supply from the switch.
The two wires at the switch are hot in and hot out (switched).
Did you note the connecttions before you took down the old light ?
What colors are the wires on the fan ?
dmxtothemax is offline   Reply With Quote
Old 02-28-2013, 10:48 PM   #9
k_buz's Avatar
There was a way of wiring a 3 way switch circuit where there could be 2 hots up at the fixture. It was called a Chicago Three Way. Its not legal anymore, but what you had was either two hots (light off), two neutrals (light off), or a hot and a neutral (light on). Based on the knob and tube, it is possible this is what you have. You may be able to rewire things to make it work correctly, but it is going to be very hard to do here.
Old 02-28-2013, 10:54 PM   #10
k_buz's Avatar
This may give you a better understanding of a Chicago Three Way...
Old 02-28-2013, 11:06 PM   #11
The 2 wires on the bottom are currently hot the one on the right goes to the light
Old 02-28-2013, 11:09 PM   #12
The wire with tape is hot from another source the other goes to the box in the other pic top right
Old 02-28-2013, 11:14 PM   #13
does the pictures help you in any way?
Old 02-28-2013, 11:17 PM   #14
and if it was wired up in the chicago three way it would be preferred to just use 1 switch so how would i rewire it. would it be easier to run new wire?
Old 02-28-2013, 11:21 PM   #15
dmxtothemax
the wires was buried under sheet rock so no i have no idea what is what. like i said the wire with tape in the second picture is hot coming from the other side of the room the other wire goes to the switch box top right picture 1.
2 breakers with black and red hots for only 2 plugs in kitchen. Y so many? Runestone Electrical 19 10-19-2012 05:35 AM
2 hots 1 neutral ? Joe Willie Electrical 9 05-06-2011 09:13 PM
Multi Wire Branch Circuit MWBC w/4X or 6X hots or more, 1X oversized neutral mysterylectric Electrical 7 05-05-2011 10:16 PM
wiring a light fixture with a two hots and two neutrals Mike48becker Electrical 2 11-10-2010 09:15 PM
210V outlet with no ground, hot and netural reversed Maximo Electrical 4 03-05-2010 10:15 AM
