2 Hot Wires From Switch - Previously A Switched Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 06-14-2014, 01:32 PM   #1
2 Hot Wires from Switch - Previously a Switched Outlet
Hi,
I am trying to replace a half switched outlet with 2 switches.
I was able to replace the outlet that is half switched with another outlet without the tab broken. I did not change any wiring just unwired the old switch and rewired a new switch without a broken tab. Now both outlets worked us switched.
At the switch I want to have a total of 2 switches. 1 switch to control recessed lights and the other one to control a fan.
When I test the wires I have 2 black wires pigtailed together that are hot and then I have a single black wire that is hot. Plus 3 white wires that are wired together.
I am not sure how to wire these switches. Single poles switches.
If there was only one hot black wire I would just pigtail that hot wire to both of my incoming wires and then to the switch. Then I would pigtail the ground and the white neutral.
But I have 2 hot wires.
Also not sure if it has to do with this previously bring a switched outlet.
eric6552 is offline   Reply With Quote
Old 06-14-2014, 02:00 PM   #2
Rob
Robpo's Avatar
Rewards Points: 826
Do you have 2 hot wires when switch is off? Check your wording.
Robpo is offline   Reply With Quote
Old 06-14-2014, 02:11 PM   #3
Rewards Points: 3,396
ah...
what?
ritelec is offline   Reply With Quote
Old 06-14-2014, 02:22 PM   #4
There are different types of outlets.
lighting outlets, receptacle outlets.
lets call your wall plugs = receptacles, and your switches = switches.
It looks like you call your receptacles outlets then switches in the same sentence.
At your receptacle, you did not break of the tab so power is sent back to the switch that that half of the receptacle was controlled from.
At your switch location,
two black wires are spliced together with a pigtail coming from the splice to the switch.
That is probably your hot.
There's a single black, that's probably going out to something thats "switched", I'd say the receptacle that you replaced but something doesn't look right (but maybe they did go to that receptacle with 2-2 wires),
The neutrals (3) get spliced together.
How where those neutrals before you got to them, they don't look like they where spliced (too straight)?
Old 06-14-2014, 02:41 PM   #5
Rob
Robpo's Avatar
Rewards Points: 826
I think the OP wants two switches in one single box to control two separate receptacles separately in another box. I think I worded that right.
Old 06-14-2014, 02:45 PM   #6
I "think" the OP wants a fan switch and light switch in that box.
But where's the fan and lights ?
Old 06-14-2014, 02:54 PM   #7
Clairifaction to My Original Post
I would like each switch to control a fan and a light. the receptacle that was half switched I just want that to be powered on all the time and not be a switched receptacle.
Currently the 2 black wires are pigtailed together and they are hot. Not connected to a switch. Also the single black wire is hot not connected to a switch.
As far as the single black wire I do not know where it is coming from just that it is hot. Same for the 2 black wires that a tied together. This is all in the box where the switch is. Not the receptacle.
The neutrals have always been tied together.
I can add more pictures if needed.
Thanks for all the posting.
Old 06-14-2014, 02:57 PM   #8
Rob
Robpo's Avatar
Rewards Points: 826
You mean where's the box?
Old 06-14-2014, 02:59 PM   #9
eastcoastsparky's Avatar
Rewards Points: 150
First things first, tie the noodles back together before you fry something
eastcoastsparky is offline   Reply With Quote
Old 06-14-2014, 02:59 PM   #10
that's probably the wire that was feeding your receptacle for the switched outlet.
which you did't break the tab so it will always be hot.
Old 06-14-2014, 03:00 PM   #11
The box is where all the hot wires are. This is where I ran the 14-2 from the fan and lights.
I added a 2 gang box to support the additional switch. See photo.
Old 06-14-2014, 03:02 PM   #12
I don't think there are any yet.
I think this is the star to the project.
1- make both receptacles on duplex outlet hot.
2- install high hat fixtures from a wall operated switch (dimmer).
3- install paddle fan from wall operated switch (speed control).
Old 06-14-2014, 03:04 PM   #13
ok moving right along, the plot thickens
you're there.
splice it up
Old 06-14-2014, 03:10 PM   #14
Do I just pigtail all 3 black wires and then run a wire to one of each of the switches?
Old 06-14-2014, 03:18 PM   #15
leave the single black wire wire nutted and alone.
put it to the back of the box.
The two that are spliced with a pigtail.
Splice it so it has two pigtails.
one pigtail will go to each switch.
All whites together.
All grounds together with two pigtalis, one to each switch.
Rewire a switch that controls an outlet. z00ropa Electrical 8 10-23-2012 06:00 PM
Electrical wiring/ switch wiring - mixed wires tien009 Electrical 1 07-21-2012 10:53 PM
Combo light switch outlet re-wire question seasidediy Electrical 3 07-21-2011 05:02 AM
Changing 2 way switch to control light, not outlet? andysam Electrical 0 05-30-2011 09:20 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
