2 Grounds Under One Screw In My Panel? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-09-2010, 09:33 PM   #1
Just call me Andrew
Rewards Points: 1,020
2 grounds under one screw in my panel?
Is it allowed? I am talking about equipment grounds, NOT grounded (neutral) wires. If it matters, it's a Cutler-Hammer CH 100-amp panel.
Thanks.
Andrew
secutanudu is offline   Reply With Quote
Old 05-09-2010, 09:42 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,864
This is fine. Some even allow three grounding conductors of the same size.
Old 05-09-2010, 09:43 PM   #3
Licensed electrician
Rewards Points: 1,236
Yes, the CH bar is listed for 2 grounding conductors. Check the label inside the panel for sizes and numbers.
Old 05-09-2010, 09:44 PM   #4
Master Electrician
legally...depends on your inspector
is it safe? if the screw is tight then certainly.
andrew79 is offline   Reply With Quote
Old 05-09-2010, 09:46 PM   #5
No, legally it depends on the code and the listing of the panel.
If the panel is listed to accept two grounding conductors of the same size an inspector CANNOT prohibit you from doing it, unless of course there is a local code amendment prohibiting it.
Old 05-09-2010, 09:51 PM   #6
Just call me Andrew
But if one is a 14- and one is 12-awg....not allowed? Didn't know that. Guess I'll have to fix it.
Andrew
Main panel or sub panel? tbeaulieu Electrical 5 04-07-2010 12:58 PM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 09:43 PM
Melted Service Entrance Wire in Panel theatretch85 Electrical 13 08-22-2008 11:37 AM
breaker panel question chadvavra Electrical 11 08-10-2007 10:20 AM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 06:44 PM
