12-14-2012, 08:21 PM
#1
2 ground rods for homes in tx
I only have one gr rod for my home I live in Bryan tx I don't know a lot about it and I've never heard of 2 gd rods here what is the purpose of 2 I've been hearing y'all talk about.
12-14-2012, 08:25 PM
#2
Licensed electrician
Unless it can be proved that the one rod is enough to get the resistance down below 25 ohms the code requires an additional electrode. It is easier to drive two rods and be down with it and avoid the need to show the inspector your testing of the one rod.
Once the second electrode is driven there is no requirement to keep adding electrodes to get below 25 ohms.
12-14-2012, 08:46 PM
#3
DIY Enthusiast
I believe the 2 ground rods were decided as an alternate to the one.with just one rod,code requires a rather expensive test to determine if it will fall below a certain #. I think 2 rods will not give you any more protection then the one you already have.
The Following 2 Users Say Thank You to sublime2 For This Useful Post:
12-15-2012, 10:28 AM
#4
I have only one myself. It was inspected when I did the service upgrade about 15 years ago. I have no intentions to install another one, nor am I required to.
The Following User Says Thank You to J. V. For This Useful Post:
12-15-2012, 10:58 AM
#5
Lic Elect/Inspector/CPO
It will give you more protection since each ground rod is on a different ground plane.
The Following User Says Thank You to NJMarine For This Useful Post:
12-15-2012, 11:06 AM
#6
DIY Enthusiast
In theory.
The Following User Says Thank You to sublime2 For This Useful Post:
12-15-2012, 11:11 AM
#7
Two ground rods will lower the effective resistance to ground, thus providing a more conductive path. For example, if each ground rod is 30 ohms, two ground rods in parallel will present a resistance of 15 ohms. The lower the resistance, the more current will flow to ground, as opposed to some alternate path.
The Following User Says Thank You to Dave632 For This Useful Post:
12-15-2012, 08:34 PM
#8
this and other recent ground rod discussions prompts me to ask the following question. If a service is bonded to an incoming copper water service, is any better protection provided by one or more ground rods? In my case the water service is about 40 feet away from the service entrance panel and any additional ground rods would be within a couple of feet of the panel. I understand that the cold water service ground met the code when the house was built in 1985. The copper water service is about 50 feet long to the street which is a cast iron main.
bernie
12-15-2012, 08:52 PM
#9
Lic Electrical Inspector
The NEC does not require test. The inspector can request a megger test. Since he has to witness the test and can take several days to get to the job for the test. It is easier to drive the second rod and forget about it. Otherwise the EC can sit and wait for the EI to witness the test. If the test proves less than 25 ohms, no second rod is required.
All responses based on the 2011 NEC.
If you live in New Jersey click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . All other states click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. .
Please check with local, county and state officials as laws may vary.
Sizing motors To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Online motor calculator To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Online calculators To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. .
The Following User Says Thank You to electures For This Useful Post:
12-15-2012, 09:24 PM
#10
DIY Enthusiast
Well if there's no test then how does one know that 2 rods will do the job and not just one rod?
12-15-2012, 09:33 PM
#11
We don't. The NEC does not require more then two rods. I don't require the second rod. But if there is only one rod, I request the megger test. I have three days to complete the inspection including witness the test. It is cheaper to just drive two rods and be done with it.
The Following 2 Users Say Thank You to electures For This Useful Post:
12-16-2012, 01:01 AM
#12
Look up your power company provider web site on installation requirements.They require us to use 2 rods at least 6 feet apart,no asterick about only 1 if you can show 1 rod does the job. This is for new installs of course,not existing.
The Following User Says Thank You to bobelectric For This Useful Post:
12-16-2012, 07:05 AM
#13
I should ask, if the building has an entering water pipe or a concrete reinforcing bar as a grounding electrode, is just one ground rod sufficient?
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
12-16-2012, 09:21 AM
#14
Hey Allen you may have to start a new thread on that to get a answer
12-16-2012, 09:32 AM
#15
Licensed Electrician
No. If you use rod[s], you must be less than 25 ohms or drive a second rod. Even if you have properly bonded the other electrodes.
Note: There is some issues that do arise with Ufers. Some people will tell you that all you need to do is bond to the Ufer and nothing else. However, in my area, the Ufer only takes the place of the rods, and you will have to bond to water if present.
Location...Location...Location
The Following User Says Thank You to k_buz For This Useful Post:
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
