2 Ground Bars In Sub Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 06-14-2007, 07:50 PM   #1
2 Ground Bars in sub panel
Hi folks! I will be installing a new sub panel, 100A. i would like this neat and tidy, but above all safe. My branch circuits will be be coming in at both sides of the box, hots going to thier respective breakers and neutrals to thier new homes on both sides of the box. Since some of the grounds will not reach the bottom of the ground bar, I would like to install 2, one on each side. What is the proper way to bond them? Can I use lugs on each bar w/#6 or can I use the holes in the bar? Thanks an advance.
Paul_D is offline   Reply With Quote
Old 06-14-2007, 08:22 PM   #2
Number 6 ground from main panel to first ground bar. Number 6 ground from first ground bar to second ground bar.
Both ground bars mounted to the panel with machine screws in tapped holes, or with self tapping screws that are provided by the mfg of the panel.
Master Electrician
jwhite is offline   Reply With Quote
Old 06-14-2007, 08:57 PM   #3
Thanks for the response. I was just curious if it is mandated that I use lugs when connecting the bars together. Great site. I could browse for hours!
Old 06-14-2007, 09:02 PM   #4
the LUG is where you will turn the screw down to tighten the wire I mentioned above.
Yes you need those.
Master Electrician
Old 06-14-2007, 09:26 PM   #5
Cool! I have plenty of 'em. Thanks again.
Old 06-14-2007, 10:25 PM   #6
dont forget to float your neutrals.
-gooch
gooch is offline   Reply With Quote
12v diff between ground and neutral at panel am9518 Electrical 7 02-25-2008 07:28 PM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 06:44 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 07:30 PM
wire to a workshop jim c Electrical 11 03-02-2007 04:41 PM
Splice in Neutral to Panel - OK or Not? allpraisebob Electrical 4 08-12-2006 06:54 AM
