-   -   2 Gang Wall Plate with one switch and blank? (http://www.diychatroom.com/f18/2-gang-wall-plate-one-switch-blank-126490/)
ctandc 12-13-2011 09:29 AM
I searched, but I must be missing something. Do they even make this?
I've got an outlet in my living room that is now used for my TV / home theater stuff. I have a surge protector installed at the outlet.
There are three different switches in the same room which turn this outlet on / off.
They are all normal toggle switches.
Two of them reside in a 3 gang plate with two other toggle switches. The third switch is in a 2 gang plate with another switch.
I want to remove these 3 switches, wire them together, and then install a wall plate in each location which will cover this now removed switch but still have a spot for the remaining switches.
Does that make sense?
I've looked and looked but can't find anything like this. I can't be the first one to need this, I'm sure I'm just doing something wrong when looking.
Thanks for any help.
McSteve 12-13-2011 09:40 AM
Your local Home Depot should have one or two things that would work.
I used Leviton modular wall plates, they come in snap-together sections so that you can build exactly the plate you need. I used one of these in my garage where I needed a two-gang plate with a switch on the left and blank on the right.
There are also switch filler plates that install in place of a switch and cover the hole in the existing plate, though I can't remember for sure if I saw them at Home Depot.
ctandc 12-13-2011 12:39 PM
Thanks for the reply. I was able to find what I needed by digging through the Leviton Catalog....the modular plates you referred to will fill bill nicely.
Thanks again.
