2 Gang Old Box, Made Into 3 Gang, Off Center?? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-14-2010, 04:58 PM   #1
Rewards Points: 150
2 gang old box, made into 3 gang, off center??
please help....
what i want to do is this...
currently I have 2 switches in a 2 gang box. ok no big deal.
my plans are to add another switch and make it into a 3 gang, but not really a 3 gang. the old box on the left will be 2 gang, and the new work single box will be on the right to that. but i want to be able to use one big plate cover that has 3 slots for the switches. is this possible? seems like it will be off center and eventually i wont be able to put the plate on because the new single gange box on the right will be too much to the right. any ideas?
also i think it would be stupid looking if i left it with the 2 gang then about 5 inches to the right there would be a seperate switch box.. so my plans is to keep the exsisting 2 gang and add another new work right next to that to be able to use one big plate
fabian is offline   Reply With Quote
Old 01-14-2010, 05:00 PM   #2
You need a 3 gang box if you want to use a 3 gang faceplate
Buy a double switch & replace one of the single switches
Problem solved
Old 01-14-2010, 05:05 PM   #3
Rewards Points: 150
Problem solved
great idea. now would they make a switch like that but one of them dimmable?
Old 01-14-2010, 05:07 PM   #4
Rewards Points: 150
how hard would it be removing that 2 gang old box without damaging the sheetrock?
Old 01-14-2010, 05:16 PM   #5
Hard to say
Is it nailed in ?
Metal with a plate across the face of the stud ?
Old 01-14-2010, 06:54 PM   #6
Inspector/Instructor
codeone's Avatar
This is a typical nail up box.
You could possibly take a hacksaw blade without the saw and carefully cut the nails and push the box down in the wall.
codeone is offline   Reply With Quote
Old 01-14-2010, 06:56 PM   #7
codeone's Avatar
This is another style. Have never tried one of these the nail up is the most common.
Old 01-14-2010, 07:48 PM   #8
Licensed Pro
If you only need one of the three to be a dimmer, shift things around so the "solo" switch is the dimmer.
Old 01-15-2010, 10:03 AM   #9
Rewards Points: 150
thanks guys for the replies, i am switching things around so the dimmer is on its own.
Old 01-15-2010, 10:46 AM   #10
Just call me Andrew
Rewards Points: 1,020
They also make dual rocker switches, you may like the look of them better:
Andrew
secutanudu is offline   Reply With Quote
Jacking up house, full length joists raised beam off of center colums. Suggestions? slowjo Building & Construction 9 09-16-2014 07:56 AM
Ductwork Around Center Beam Build HVAC 6 06-16-2009 11:56 AM
Load center vs. bottom fed Panel Board. Ugh. wmldwilly Electrical 8 04-23-2009 08:48 PM
Moved ceiling light in bedroom to center, now trips breaker blthomas Electrical 18 01-24-2008 05:29 PM
Drilling into Center Beam leted_82 Building & Construction 2 03-06-2007 09:52 PM
