-   -   2 gang old box, made into 3 gang, off center?? (http://www.diychatroom.com/f18/2-gang-old-box-made-into-3-gang-off-center-61860/)
fabian 01-14-2010 04:58 PM
please help....
what i want to do is this...
currently I have 2 switches in a 2 gang box. ok no big deal.
my plans are to add another switch and make it into a 3 gang, but not really a 3 gang. the old box on the left will be 2 gang, and the new work single box will be on the right to that. but i want to be able to use one big plate cover that has 3 slots for the switches. is this possible? seems like it will be off center and eventually i wont be able to put the plate on because the new single gange box on the right will be too much to the right. any ideas?
also i think it would be stupid looking if i left it with the 2 gang then about 5 inches to the right there would be a seperate switch box.. so my plans is to keep the exsisting 2 gang and add another new work right next to that to be able to use one big plate
Scuba_Dave 01-14-2010 05:00 PM
You need a 3 gang box if you want to use a 3 gang faceplate
Buy a double switch & replace one of the single switches
Problem solved
http://images.marketworks.com/hi/58/...3-i-10pk-2.jpg
fabian 01-14-2010 05:05 PM
Problem solved
great idea. now would they make a switch like that but one of them dimmable?
fabian 01-14-2010 05:07 PM
how hard would it be removing that 2 gang old box without damaging the sheetrock?
Scuba_Dave 01-14-2010 05:16 PM
Hard to say
Is it nailed in ?
Metal with a plate across the face of the stud ?
codeone 01-14-2010 06:54 PM
1 Attachment(s)
This is a typical nail up box.
You could possibly take a hacksaw blade without the saw and carefully cut the nails and push the box down in the wall.
codeone 01-14-2010 06:56 PM
1 Attachment(s)
This is another style. Have never tried one of these the nail up is the most common.
HouseHelper 01-14-2010 07:48 PM
If you only need one of the three to be a dimmer, shift things around so the "solo" switch is the dimmer.
fabian 01-15-2010 10:03 AM
thanks guys for the replies, i am switching things around so the dimmer is on its own. :thumbsup:
secutanudu 01-15-2010 10:46 AM
They also make dual rocker switches, you may like the look of them better:
http://i.s.shopwiki.com/i/data/__15+...IG_CL%20IG_CNT
