2 Doorbell Chimes To One Switch In Series? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-06-2011, 12:15 AM   #1
2 doorbell chimes to one switch in series?
I'm doing a basement renovation, and I want to install a second chime in the basement. Right now there's just one switch at the front door and one chime, in what I believe is a standard circuit, as shown in the attached pic. From what I've read, the proper way to do this would be to connect the second chime in parallel by connecting the second chime to the same wires as the first.
My issue is that the wall where my transformer and chime are upstairs is completely finished, and has a bulkhead so I'm unable to fish anything through. Therefore I only have access to the wire running between the chime and the transformer.
I'm not an electrician but as I understand it, connecting the chime into the wire between the switch and transformer would essentially connect both chimes in series. Is there any way to make it work in series? Maybe buying a 24V transformer and just a 10V chime?
Would really appreciate any advice, or pointers if my thinking on the electrical side of it is wrong... Thanks!
Felgar is offline   Reply With Quote
Old 10-06-2011, 01:30 AM   #2
Rewards Points: 6,652
http://www.familyhandyman.com/DIY-Pr...doorbell-chime
Old 10-06-2011, 01:39 AM   #3
Yeah, that mirrors what I've seen as well; connecting them in parallel from the other chime or transformer. Unfortunately they're side-by-side near the top of that finished wall. Maybe I'll look at the extend-a-chime options; seems a shame to not have a wired connection though...
Old 10-06-2011, 02:22 AM   #4
You either go wireless, or follow the information that I linked. There is no way around it, and no magic formula to change how it should be wired.
Old 10-06-2011, 02:31 AM   #5
Semi-Pro Electro-Geek
Rewards Points: 2,852
Your original idea of using a higher voltage transformer and two lower voltage chimes in series will work, as long as the two chimes draw the same amount of current. The only good way to ensure that is to use a pair of identical chimes, so you may need to replace both of them so they match. Choose a transformer with twice the rated voltage of the chimes - e.g. a 24V transformer with 12V chimes. This is a highly non-standard installation but it will work just fine.
mpoulton is offline   Reply With Quote
Old 10-06-2011, 08:21 AM   #6
biggles's Avatar
how about snaking down from the button and connect the downstairs there land the wires and your parallel'd ..down behind a molding
Old 10-06-2011, 12:57 PM   #7
Not sure what you're suggesting here... I have the wire available from the button, but only between the button and the transformer.
It just occurred to me though, what would work would be to move the transformer to the basement... It would mean a little more 120V wiring but at least it would then be a standard installation...
Old 10-06-2011, 01:05 PM   #8
Here, make it easy on yourself http://www.1800doorbell.com/db800-extend-a-chime.htm
Old 10-06-2011, 01:23 PM   #9
Thanks Gregzoll. It looks like that would be a decent option. The only downside is that I'd really like one with a strobe (going into a home theatre) but no strobe models seem to work with the extend-a-chime. Maybe I'll need to settle for just a very loud chime...
Old 10-06-2011, 03:49 PM   #10
biggles's Avatar
if you can snake a pair of wires up to the exsisting door bell just land them there for that basement button
confused on switch replacement fullpint Electrical 6 07-11-2011 09:39 AM
3-way switch help amit Electrical 17 02-15-2010 04:17 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 07:14 PM
old wire, backfed switch question Jack A. Trades Electrical 6 07-03-2008 12:05 PM
