2 Circuits Less - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-21-2011, 10:00 PM   #16
2 column panel, dryer had power (I think) lost track now. So far 2 bad breakers and one circuit no power at all, and possible another circuit out. I'm exhausted. How do you check the main?
shiggins10 is offline   Reply With Quote
Old 05-21-2011, 10:12 PM   #17
Sparky
Rewards Points: 510
do you have a multimeter?
check voltage from L1 to L2, L1 to N, L2 to N, L1 to G, and L2 to G
L1 - Line 1(usually black)
L2 - Line 2(usually red)
N - Neutral(White)
G - Ground(Green/bare)
Techy is offline   Reply With Quote
Old 05-21-2011, 10:49 PM   #18
multi meter??? and I don't have a voltage tester. Bummer. Is this how I would go about checking the main?
Old 05-21-2011, 11:05 PM   #19
Sparky
Rewards Points: 510
multimeter is just another name for voltage tester.
without one you're probably going to have to call in an electrician
Old 05-21-2011, 11:06 PM   #20
Journeyman Wireman
Rewards Points: 150
Did you figure it out? If not, I hope you called an electrician in to help.
Jupe Blue is offline   Reply With Quote
Old 05-21-2011, 11:37 PM   #21
2 circuits less
Freaky, and I mean freaky!!! the circuit that i couldn't get any power too just lit up by itself, will check the breakers that appeared to be bad again tomorrow morning.
Thanks for all your efforts and assistants, would have given up along time ago. hmmmm, do you believe in ghosts....
Old 05-21-2011, 11:54 PM   #22
Learning by Doing
Leah Frances's Avatar
No, but did you have the POCO come out to check their side of things?
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 05-22-2011, 12:23 AM   #23
Scared Electrician
Saturday Cowboy's Avatar
Why did you turn off the main breaker in the first place??????????
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 05-22-2011, 07:50 AM   #24
2 Circuits less
Well Cowboy, you just had to ask, so for your amusement. I'm putting a deck on the back of the house and the water line just wasn't in the right spot. : )
Split receptacles, double pole breakers and multiple circuits in a junction box. morganhammer Electrical 6 04-05-2011 04:38 PM
short circuit. reset the breaker, but no power bp91708 Electrical 10 03-18-2011 10:07 AM
AFCI and 3-wire circuits...ugghh mhops Electrical 11 03-17-2010 11:22 AM
Adding odd circuits in a bedroom and hood fan oh my! beatle Electrical 3 11-19-2009 07:45 AM
replacing old wire on existing circuits... red86yota Electrical 9 12-08-2008 06:00 PM
