2 Circuits Less - Electrical - DIY Chatroom Home Improvement Forum
Old 05-21-2011, 07:18 PM   #1
2 Circuits less
Turned main breaker off for a sec and now 2 circuits don't work?
shiggins10 is offline   Reply With Quote
Old 05-21-2011, 07:26 PM   #2
Rewards Points: 512
You turned the Main back on, I'm assuming. Coincidence?
Old 05-21-2011, 07:29 PM   #3
2 circuits less
yes, several times
Old 05-21-2011, 07:31 PM   #4
2 circuits less
bad part its the refrig and freezer, anddddd nightmare... daughters tv
Old 05-21-2011, 07:57 PM   #5
OK 2 circuits have power going to them, but there is one more circuit out with know power at all?
Old 05-21-2011, 08:10 PM   #6
Rewards Points: 252
Did you try resetting that circuits breaker? Is there a GFI socket in the circuit?
Marty1Mc is offline   Reply With Quote
Old 05-21-2011, 08:13 PM   #7
can check if you could tell me what GFI means
Old 05-21-2011, 08:23 PM   #8
Ironlight's Avatar
GFCI. Ground Fault Circuit Interrupter. Looks like this. They sometimes trip when you cycle the breakers. One GFCI can protect other outlets downstream from it on the same circuit. Press the button to reset it:
Ironlight is offline   Reply With Quote
Old 05-21-2011, 08:32 PM   #9
ok GFI's are not the prob in wall plugs in the kitchen
power coming into 2 main breakers and not the 3rd? I've turned the main off before several times over the years, never had a prob with all the breakers coming back on. Coincidence?
Old 05-21-2011, 08:43 PM   #10
Rewards Points: 252
OK, GFI isn't the issue. Have you tried to reset that circuits breaker? Also, check the wire in the breaker and make sure it's secure. It may just not have a tight connection to the breaker. Be careful when you do it, that's a live box.
Old 05-21-2011, 08:50 PM   #11
If your talking about turning the breakers off and than back on, done several times. Will check wiring...
Old 05-21-2011, 09:12 PM   #12
Ohhh this gets really good, breaker bad on refrig? (worked fine before shutting off main) ok but still can't get the other 2 circuits to work. Still checking
Old 05-21-2011, 09:33 PM   #13
ok two breakers bad???? why?
Working on the third
Old 05-21-2011, 09:34 PM   #14
and possibly fourth
Old 05-21-2011, 09:37 PM   #15
Electrical Contractor
jbfan's Avatar
Rewards Points: 554
Are the breakers staggered in the panel?
Does the dryer or stove work?
You may have a bad connection in the main breaker.
I have seen that happen before!
Split receptacles, double pole breakers and multiple circuits in a junction box. morganhammer Electrical 6 04-05-2011 04:38 PM
short circuit. reset the breaker, but no power bp91708 Electrical 10 03-18-2011 10:07 AM
AFCI and 3-wire circuits...ugghh mhops Electrical 11 03-17-2010 11:22 AM
Adding odd circuits in a bedroom and hood fan oh my! beatle Electrical 3 11-19-2009 07:45 AM
replacing old wire on existing circuits... red86yota Electrical 9 12-08-2008 06:00 PM
