Old 07-15-2012, 10:55 AM   #31
Licensed Electrician
k_buz's Avatar
2 Ceiling light wiring question?
I was under the impression the box in the OP was for a light, not a fan. The box you have this fan mounted to (the one shown in the OP), is not a fan rated box or is it attached to a fan rated brace. I would suggest you take the fan back down and properly support this large fan.
Location...Location...Location
k_buz is online now   Reply With Quote
Old 07-15-2012, 11:09 AM   #32
Post #22. So in the meantime I must hook a light back up. I don't want to re-install the wide light which might damage the ceiling I just fixed and painted so I decided I will put the old simple/single light from the other room which is done. This is just temporary until the fan comes in. While I am working on this, I also decided that because I have the time this weekend I will also remove the old box which could not support a ceiling fan, and install a new ceiling fan brace kit and box. So while replacing the boxes I had to disconnect the wires as they came in through different holes in the old box. Then re-route them into the new box.. ..
I should take some photos of the rentals attic showing where the old HO spliced directly into the home run with no j box, no wirenuts, and ran 22gauge wire about 15' to a ceiling fan. In 4 different locations. See what ya have to say about that one.
CopperClad is offline   Reply With Quote
The Following User Says Thank You to CopperClad For This Useful Post:
k_buz (07-15-2012)
Old 07-15-2012, 01:04 PM   #33
Yes last weekend I put in the new ceiling fan box and brace kit, but I had to temporarilly hook a light back up until the ceiling fan arrived. If I remember correctly it can support a maximum weight of 120lbs. This fan is nowhere even close to that, and it's only about 50" diameter.
Uncoiler is offline   Reply With Quote
Quick Question about Ceiling Fan LIGHT KITS watts up? Electrical 8 10-06-2011 12:04 AM
HELP! Ceiling Light Wiring Question Joeychgo Electrical 4 03-13-2011 09:04 PM
Ceiling Fan with light wiring? Snowwolf Electrical 7 06-28-2010 09:30 PM
Question with wiring up a flood light. SuperAkuma Electrical 6 09-20-2008 11:58 AM
New Ceiling fixture Wiring Question rsteps Electrical 4 07-12-2007 08:51 AM
