2 Ceiling Light Wiring Question? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-08-2012, 12:05 AM   #1
2 Ceiling light wiring question?
Ok I messed up today & got interupted by out of town company in the middle of replacing my ceiling light and box, now I can't remember where a couple wires should go.
There are 9 wires coming into this box, 3 black, 3 white, 3 ground. Here is what I am fairly certain of. There are two black wires in the Mar connector. Of the two the one on the right is live when the breaker is on, the one on the left continues that onto and electrical plug in the wall. The two white wires in the Mar connector were wrapped together just as they are now. The three gound wires were screwed to ground screws in the box.
That leaves the one black and one white wire sticking out and pointing to about 3 o'clock in the pic. I thought these two were connected to together with another Mar, but I'm not 100% certain. With the breaker off I used my ohm meter to determine that both of these go to my wall switch. And my wall switch only has two wires to it (one black and one white).
My questions are about hooking up a new light that has just one black, white, and ground.
1- Should the two wires (black and white 3 o'clock) that go to the light switch be connected together like I thought?
2-Where should my black wire and white wire from the new light go to? I hope I have explained this OK. Thank you.
Uncoiler is offline   Reply With Quote
Old 07-08-2012, 12:40 AM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
The loose white needs to be taped with black tape to signify it is actually a hot. Then put the remarked white to the two blacks already spliced together. The loose black goes to the black on the fixture and the currently spliced whites go to the white of the fixture.
The Following User Says Thank You to k_buz For This Useful Post:
Uncoiler (07-08-2012)
Old 07-08-2012, 08:44 AM   #3
Rewards Points: 2,516
here is what KBuz says to do:
I did not show ground wires for ease of drawing, but al grounds get wire nitted together at teh light fixture and dont forget to attach ground wire to the switch
hammerlane is offline   Reply With Quote
The Following User Says Thank You to hammerlane For This Useful Post:
Uncoiler (07-09-2012)
Old 07-08-2012, 09:05 AM   #4
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Why is it that everyone feels the need to take apart splices when replacing a fixture? just remove the old fixture and reinstall the new fixture the same exact way.... sorry had to vent that.
The Following 2 Users Say Thank You to stickboy1375 For This Useful Post:
jrclen (07-09-2012), Speedy Petey (07-08-2012)
Old 07-08-2012, 09:08 AM   #5
if people did as you say we would have nothing to do on a Sunday morning on an electrical forum.
stickboy1375 (07-08-2012)
Old 07-08-2012, 09:09 AM   #6
Maybe he had aluminum wire hooked to copper clad and replaced the aluminum wire with copper and then used a regular wire nut with noalox to make the new connection.
CopperClad is offline   Reply With Quote
Old 07-08-2012, 09:09 AM   #7
E2 Electrician
I honestly believe, this wiring diagram gets posted the most.
Old 07-08-2012, 09:12 AM   #8
E2 Electrician
That's just silly and still a violation.
Old 07-08-2012, 09:13 AM   #9
Because people get fixated on wire insulation color and not the actual purpose of the conductor. Ive said before, current does not care what color insulation is over the conductor.
Old 07-08-2012, 09:15 AM   #10
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
And an even sillier explanation.
Old 07-08-2012, 09:16 AM   #11
I totally agree with you guys. WHY take the splices apart??? I bet it worked before, didn't it?? Put it back the same way!!
Old 07-08-2012, 09:16 AM   #12
E2 Electrician
I concur with that, I believe when they take the fixture down they see a white conductor spliced to a black conductor and try to 'fix' the non existing problem.
The Following User Says Thank You to stickboy1375 For This Useful Post:
Old 07-08-2012, 09:30 AM   #13
I seriously beg to differ. If you took down a fixture or 2 and a few receptacles in my parents house?? You would seriously take apart every connection you found, restrip, repigtail, and then wonder to yourself how the house hadn't burned to the ground yet.. I could take some photos in the attic that would put your jaw to the ground. If I put my name on something I always check the previous installers work.
Old 07-08-2012, 09:38 AM   #14
Then that is the exception rather than the rule. We see this ALL the time here and it is extremely rare that there was anything wrong to begin with.
Old 07-08-2012, 09:43 AM   #15
Rewards Points: 166
Look at the photo of the wires in post 1. They look in pretty good condition to me. Even hammers photo wires look good.
Minus08 is offline   Reply With Quote
Quick Question about Ceiling Fan LIGHT KITS watts up? Electrical 8 10-05-2011 11:04 PM
HELP! Ceiling Light Wiring Question Joeychgo Electrical 4 03-13-2011 08:04 PM
Ceiling Fan with light wiring? Snowwolf Electrical 7 06-28-2010 08:30 PM
Question with wiring up a flood light. SuperAkuma Electrical 6 09-20-2008 10:58 AM
New Ceiling fixture Wiring Question rsteps Electrical 4 07-12-2007 07:51 AM
