Old 05-28-2012, 10:44 AM   #16
Orlando homeowner
2 Ceiling fans and 1 double pole switch
There are only 2 switches in the picture. The one hanging is the dimmer/speed control. The other is the light switch.
The two black wires were connected to the top of the dimmer/speed control and the white wires were connected to nothing. He used some brown wiring to connect to the black and white wires. I removed the speed control switch and brown wiring.
karpolu is offline   Reply With Quote
Old 05-28-2012, 10:50 AM   #17
Licensed Electrician
k_buz's Avatar
If you KNOW how it was originally wired, then just replace the speed control with the switch. Don't worry about what to do with the white wires, IF THEY WERE JUST CAPPED OFF. If they were connected (somehow) to each other, then they need to go back together.
k_buz is online now   Reply With Quote
The Following User Says Thank You to k_buz For This Useful Post:
karpolu (05-28-2012)
Old 05-28-2012, 11:00 AM   #18
Orlando homeowner
Thanks. I will connect the black wires to the screws on one side of the switch and leave the white wires capped.
2 ceiling fans on single wall switch Zig Electrical 5 03-06-2012 10:16 PM
two industrial ceiling fans on one switch arusillon Electrical 4 01-17-2012 05:57 PM
3 Ceiling fans bodekms Electrical 9 06-14-2011 07:59 AM
Single Pole Switch is "Hot" to the Touch mbaudler Electrical 7 12-15-2010 12:28 PM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 07:32 PM
