2 Ceiling Fans And 1 Double Pole Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 05-27-2012, 09:04 PM   #1
Orlando homeowner
2 Ceiling fans and 1 double pole switch
Hello,
I am changing a dimmer switch to a double pole light switch to control 2 ceiling fans with no lights. Inside the switch are 2 white, 2 black and 2 bare wires. The bare wires are wrapped together leaving the 2 white and 2 black wires.
How do I wire to a double pole light switch? I kinda have an idea but I don't wanna burn my house down.
Thanks for any advice!
Karl
karpolu is offline   Reply With Quote
Old 05-27-2012, 09:34 PM   #2
Electrical Contractor
kbsparky's Avatar
Why do you think you need to use a double-pole switch? Are these 2 fans on separate circuits?
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
plummen (05-27-2012)
Old 05-27-2012, 09:47 PM   #3
Orlando homeowner
So I only needed a single pole switch? I was thinking 1 fan per side.
The black and white pairs have the dimmer attached hanging outside of the picture.
Old 05-27-2012, 10:08 PM   #4
Master Electrician
wow that's an ugly looking box, always nice when you see copper stinking out of the wire nuts everywhere. A picture including the dimmer would be more helpfull.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 05-27-2012, 10:56 PM   #5
Orlando homeowner
When I wire the switch, the yellow wire nuts will go away.
Old 05-28-2012, 03:18 AM   #6
kbsparky's Avatar
What a rats nest! You need to zoom back a bit so we can see all the connections, and which wires are connected to which.
-KB
Old 05-28-2012, 04:26 AM   #7
Orlando homeowner
I removed the dimmer switch. All that remains are the 2 pairs of black and white wires and the 2 bare wires which are connected to each other with the yellow wire nut in the back of the switch box.
Old 05-28-2012, 04:33 AM   #8
kbsparky's Avatar
It's still impossible for one to determine which wire was connected where, with part of the photo cropped... How was that dimmer originally connected, and did it properly control both fans?
-KB
Old 05-28-2012, 07:55 AM   #9
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Why are there two dimmers and a 3 way switch in that 2 gang box?
Old 05-28-2012, 09:14 AM   #10
Orlando homeowner
Its a 2 switch box with a dimmer and a light switch. In the original setup, there are 2 ceiling fans and 3 light fixtures on the patio. In the switch box there are a dimmer switch and a regular light switch. The light switch on the right in the picture controls the 3 lights. The dimmer switch that I have removed controlled the 2 ceiling fans (previous homeowner did this).
The dimmer switch on the left has the 2 black wires connected to it and the white wires are capped off with wire nuts. The two bare wires are connected to each other. For now, I have removed the dimmer switch and capped off the 2 black and white pairs of wires (no copper showing ).
With the dimmer switch gone, I'm left with just the wires.
Thanks again.
Old 05-28-2012, 09:19 AM   #11
k_buz's Avatar
edit.....
Old 05-28-2012, 09:26 AM   #12
k_buz's Avatar
I am thoroughly confused on what you have already done.
There was an existing fan/speed control that controlled two fans?
In one picture there are two fan/speed controls and a separate switch. Was that switch existing? Did you change the wiring to install the second fan/speed control?
I have an idea of what should be done, but something isn't adding up in your descriptions of what you have already done vs what was existing.
Old 05-28-2012, 09:29 AM   #13
k_buz's Avatar
If I am reading this right, you need to install a single pole switch using the same wires that the dimmer/fan-speed control used.
You should just connect the 2 whites together (like they were) and put one black to each screw on the single pole switch.
You can use a double pole switch if you have bought it already, just put both wires on the same side (one on the top, one on the bottom).
Old 05-28-2012, 09:32 AM   #14
Licensed electrician
Rewards Points: 1,790
Looked to me like two switch loops, but the single dimmer or speed control has me confused.
Old 05-28-2012, 09:33 AM   #15
k_buz's Avatar
The part that is confusing me is that if there was only one fan/speed controlled installed originally, why are two shown in the pictures?
2 ceiling fans on single wall switch Zig Electrical 5 03-06-2012 09:16 PM
two industrial ceiling fans on one switch arusillon Electrical 4 01-17-2012 04:57 PM
3 Ceiling fans bodekms Electrical 9 06-14-2011 06:59 AM
Single Pole Switch is "Hot" to the Touch mbaudler Electrical 7 12-15-2010 11:28 AM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 06:32 PM
