-   -   2 Ceiling fans and 1 double pole switch (http://www.diychatroom.com/f18/2-ceiling-fans-1-double-pole-switch-145066/)
karpolu 05-27-2012 09:04 PM
Hello,
I am changing a dimmer switch to a double pole light switch to control 2 ceiling fans with no lights. Inside the switch are 2 white, 2 black and 2 bare wires. The bare wires are wrapped together leaving the 2 white and 2 black wires.
How do I wire to a double pole light switch? I kinda have an idea but I don't wanna burn my house down.
Thanks for any advice!
Karl
kbsparky 05-27-2012 09:34 PM
Why do you think you need to use a double-pole switch? Are these 2 fans on separate circuits?
karpolu 05-27-2012 09:47 PM
So I only needed a single pole switch? I was thinking 1 fan per side.
The black and white pairs have the dimmer attached hanging outside of the picture.
http://i157.photobucket.com/albums/t...ch-resized.jpg
andrew79 05-27-2012 10:08 PM
wow that's an ugly looking box, always nice when you see copper stinking out of the wire nuts everywhere. A picture including the dimmer would be more helpfull.
karpolu 05-27-2012 10:56 PM
When I wire the switch, the yellow wire nuts will go away.
http://i157.photobucket.com/albums/t...Y/IMAG0112.jpg
kbsparky 05-28-2012 03:18 AM
What a rats nest! You need to zoom back a bit so we can see all the connections, and which wires are connected to which.
karpolu 05-28-2012 04:26 AM
I removed the dimmer switch. All that remains are the 2 pairs of black and white wires and the 2 bare wires which are connected to each other with the yellow wire nut in the back of the switch box.
kbsparky 05-28-2012 04:33 AM
It's still impossible for one to determine which wire was connected where, with part of the photo cropped... How was that dimmer originally connected, and did it properly control both fans?
k_buz 05-28-2012 07:55 AM
Why are there two dimmers and a 3 way switch in that 2 gang box?
karpolu 05-28-2012 09:14 AM
Its a 2 switch box with a dimmer and a light switch. In the original setup, there are 2 ceiling fans and 3 light fixtures on the patio. In the switch box there are a dimmer switch and a regular light switch. The light switch on the right in the picture controls the 3 lights. The dimmer switch that I have removed controlled the 2 ceiling fans (previous homeowner did this).
The dimmer switch on the left has the 2 black wires connected to it and the white wires are capped off with wire nuts. The two bare wires are connected to each other. For now, I have removed the dimmer switch and capped off the 2 black and white pairs of wires (no copper showing :) ).
With the dimmer switch gone, I'm left with just the wires.
Thanks again.
http://i157.photobucket.com/albums/t...Y/IMAG0114.jpg
k_buz 05-28-2012 09:19 AM
edit.....
k_buz 05-28-2012 09:26 AM
I am thoroughly confused on what you have already done.
There was an existing fan/speed control that controlled two fans?
In one picture there are two fan/speed controls and a separate switch. Was that switch existing? Did you change the wiring to install the second fan/speed control?
I have an idea of what should be done, but something isn't adding up in your descriptions of what you have already done vs what was existing.
k_buz 05-28-2012 09:29 AM
If I am reading this right, you need to install a single pole switch using the same wires that the dimmer/fan-speed control used.
You should just connect the 2 whites together (like they were) and put one black to each screw on the single pole switch.
You can use a double pole switch if you have bought it already, just put both wires on the same side (one on the top, one on the bottom).
Jim Port 05-28-2012 09:32 AM
Looked to me like two switch loops, but the single dimmer or speed control has me confused.
k_buz 05-28-2012 09:33 AM
The part that is confusing me is that if there was only one fan/speed controlled installed originally, why are two shown in the pictures?
