2 Breakers With Black And Red Hots For Only 2 Plugs In Kitchen. Y So Many? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-18-2012, 08:13 AM   #16
Thanks for all the advice, the wire is indeed 14-3 and after looking at the plugs again they were split plugs and from what i understand then it is agsinst code to use a 15amp single pole gfci receptacle on a 15amp circuit and discontinue use of the 3rd wire inside the 14-3 cable?
Runestone is offline   Reply With Quote
Old 10-18-2012, 10:29 PM   #17
Master Electrician
Correct
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 10-19-2012, 05:12 AM   #18
Electrical Contractor
kbsparky's Avatar
The OP must be in Canada. They allowed 15 Amp circuits for kitchen counters at one time, if you ran a split-wired circuit.
GFCI protection for kitchens was added in the 1987 Code, for outlets within 6 feet of a sink.
-KB
Old 10-19-2012, 05:27 AM   #19
Master Electrician
The motor home is from 79. Splits were good in the u.s then as well I thought.
Old 10-19-2012, 05:35 AM   #20
kbsparky's Avatar
You could have splits as you call them, but the US has required 20 Amp circuits for kitchen counter areas for many more years ...
BUT, those pesky HUD rules supercede the NEC, so who knows (Shrug) ?
-KB
