2 Breaker Boxes On 4th Floor 3 Family - Electrical - DIY Chatroom Home Improvement Forum
Old 04-02-2014, 07:10 AM   #1
2 breaker boxes on 4th Floor 3 family
I am adding with my friend all new 20amp receptacles on the 4th floor.
It's a regular 200a service coming in there is to be a total of 4 40a
breakers that we want on the floor itself. So naturally the power needs to be sent from the basement(service entrance) all the way up to this 4th floor.
This absolutely falls under diy but I am not sure if this has been specifically requested since it is a little strange since technically i guess it wouldn't be a subpanel. Just an extension of the main and putting the breakers up on the same floor..
Thoughts?
amico987 is offline   Reply With Quote
Old 04-02-2014, 07:18 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
WHAT are you asking??? Your post is extremely confusing.
Where do 40A breakers come into play?
WHY 20A receptacles?
The Following User Says Thank You to Speedy Petey For This Useful Post:
Jim Port (04-02-2014)
Old 04-02-2014, 08:57 AM   #3
joed's Avatar
Rewards Points: 13,354
Adding 4 40 amp breakers is a considerable addition to the 200 amp panel. Is this for a tankless water heater? If so the 200 amp service could be overloaded. You might need to increase it.
We need more info.
Old 04-02-2014, 10:53 AM   #4
Master Electrician
Rewards Points: 3,920
DIY + multi family = questionable.
brric is offline   Reply With Quote
The Following 4 Users Say Thank You to brric For This Useful Post:
gregzoll (04-03-2014), Jim Port (04-02-2014), Speedy Petey (04-02-2014), stickboy1375 (04-02-2014)
Old 04-03-2014, 06:37 PM   #5
Sorry if I was confusing. Think of my question this way.
Picture the top floor in question. All I am doing is trying to figure out the best way to have the said breakers in a box located on the top floor instead of all the way in the basement. The power has been accounted for so no need for a service increase.
20 A receptacles because that's what was requested. I was told the highest load might come from a hair dryer.
Old 04-03-2014, 06:50 PM   #6
Licensed electrician
Rewards Points: 1,786
I doubt the hair dryer has a 20 amp cord cap.
Regular receptacles cannot be used on greater than a 20 amp circuit.
Old 04-03-2014, 06:53 PM   #7
You want the breakers located at the top floor, but you wouldn't consider this a sub-panel?
I think you need to contact a qualified electrician.
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
gregzoll (04-03-2014), Jim Port (04-03-2014)
Old 04-03-2014, 07:39 PM   #8
Rewards Points: 6,652
Why is the power accountable? Did it do something wrong?
There is nothing wrong with pulling the branch circuits from the 4th floor of buildings, to the basement.
It does make it easier if each floor has its own individual sub-panel if this is a Multi-Tenement Structure. Then one Main panel in the Basement.
Really need more information why you are going to all of this trouble with multiple sub-panels, and why the power has to be accountable. Also it is hard to picture what a 4th floor of a building is like. Since every building is never the same way.
Old 04-03-2014, 11:36 PM   #9
dmxtothemax's Avatar
Rewards Points: 5,512
What is there on the current main panel ?
Is there room for the extra breakers ?
Is there enough current capacity available ?
How many circuits do you want on the forth floor ?
You will most likely need a small sub panel on 4th floor !
Be real sure you know what your doing !
This is serious stuff man !
With the potentual to kill, mame or burn down the entire building.
dmxtothemax is offline   Reply With Quote
New Breaker installed- Main Breaker trips novy31 Electrical 14 10-30-2013 08:08 AM
Where is the main breaker! hohadcr Electrical 8 03-27-2013 11:15 AM
3 way switch trips breaker over night Hazelberg Electrical 5 09-21-2012 09:34 PM
Is it possible to change Circuit breaker to Buss fuse socket type? njchen24 Electrical 8 08-07-2011 06:27 PM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 08:59 PM
