Old 03-11-2010, 01:26 PM   #1
2 Black Wires
I'm installing a hanging light fixture, and the fixture has 2 black wires. Which one do I connect to white ceiling wire and which to black? The only difference in the fixture wires is one is marked with text that says, in part "300 V". The other wire is plain black.
DaveSteel is offline   Reply With Quote
Old 03-11-2010, 01:30 PM   #2
Licensed electrician
2 Black Wires
The wire connected to the screw shell should connect to the building white wire. You may need a continuity tester to identify which is which.
Old 03-11-2010, 01:32 PM   #3
Master Electrician
2 Black Wires
Read the instructions that came with the fixture. Perhaps one wire is ribbed and one is smooth? Perhaps one is copper color and the other is silver colored? The wire connected to the center contact of the lampholder should be connected to the black in the junction box.
brric is offline   Reply With Quote
Old 03-11-2010, 01:47 PM   #4
2 Black Wires
I don't have the instructions.
One wire (the unmarked black wire) is ribbed. The other (marked with text) is smooth.
If I just guess and the wires are connected backward, is that a fire hazzard?
Old 03-11-2010, 01:55 PM   #5
Licensed Pro
2 Black Wires
Ribbed wire goes to the white in the ceiling, smooth to black.
Old 03-11-2010, 02:04 PM   #6
Master Electrician
2 Black Wires
I agree. No fire hazard but a shock hazard.
Old 03-11-2010, 02:11 PM   #7
2 Black Wires
Thank you!
(By the way, at the socket, the wires are black and white. So somewhere in the lamp they switch from black/black to black/white. But I can't get into that part of the lamp. I'm close, but i can't fully see how they are connected.)
Unfused connectors MELTED House wires WHAT TO DO??? jamiedolan Electrical 63 02-12-2009 07:01 PM
can't get new light fixture to work carolcwilson Electrical 24 08-12-2008 01:52 PM
Heil DC90 - AC Wires keithshank HVAC 1 07-31-2008 09:37 PM
ceiling fan installation PLEASE someone help finleygoddess7 Electrical 35 03-08-2008 10:41 PM
Different color wires on new doorbell transformer.... ConstantChange Electrical 31 11-22-2007 12:08 AM
