2 Black "hot" Wires? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-25-2011, 05:02 PM   #1
2 black "hot" wires?
I am replacing two switches, one of which had two black wires (see pic, wires on right side) attached to one screw. The switch turns on a light just outside the house as well as the garage light. I don't know much of anything about wiring, but I don't think it seemed right to attach 2 black wires to a single screw, correct? What should I do about the two wires? Any ideas would be of great help.
Elonny is offline   Reply With Quote
Old 07-25-2011, 05:05 PM   #2
Rewards Points: 1,512
When two wires want to go under one screw, cut a third, short, length of wire (about 5-6 inches) of the same* color and attach that to the screw. Connect the other end of this short piece (called a pigtail) to the other 2 wires.
* You can mix red and black. You can use bare wire to attach to green wires.
Old 07-25-2011, 08:52 PM   #3
Thanks, I did just what you said and it works just fine!
Both wires in switch are black Manshri Electrical 3 02-06-2011 07:47 AM
Hooking up a stove range, all wires are black how do tell which is positive and negative and ground? darugg Appliances 4 09-17-2010 08:19 AM
2 Black Wires DaveSteel Electrical 6 03-11-2010 01:11 PM
can't get new light fixture to work carolcwilson Electrical 24 08-12-2008 12:52 PM
Different color wires on new doorbell transformer.... ConstantChange Electrical 31 11-21-2007 11:08 PM
