2 Basic Question - Electrical - DIY Chatroom Home Improvement Forum
Old 12-20-2012, 02:38 PM   #1
2 Basic question
Hi and thanks in advance for help. Redoing laundry room
1) washer and dryer should be on separate circuit? This is not the case for me as a small bathroom exhaust fan/light and vanity light branch off in adjoining room. It's a 20 amp circuit
and total amps if everything on is 18.5. Is this okay or should I have a separate circuit wired to laundry room so it's by itself. Access to do this is not an issue.
2) light box over sink needs to be moved next to stud (it's on it now but there was a drop ceiling) I am doing a drywall ceiling now so need to move box off stud and next to it. If I do this, Box's back side will touch the sheet metal of hot air supply. My concern is a short could potentially make hvac throughout house hot? Is this a valid concern? Is there something skinny to put behind it to insulate from conduction?
Thanks again.
aechabot is offline   Reply With Quote
Old 12-20-2012, 03:28 PM   #2
Licensed electrician
Rewards Points: 1,888
An electric dryer will require a 30 amp 240 volt circuit. Washers are 120 volt. The code requires a 20 amp 120 circuit to serve only receptacles in the laundry area. The dryer, if gas, can share this circuit.
If you are using metal boxes, the box should laready be grounded, so touching the duct should not be an issue. With a plastic box it is even less of an issue.
basic gas heating question diy'er on LI HVAC 10 11-09-2012 04:14 AM
basic code question deko Electrical 3 01-13-2011 01:26 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
Basic wood cutting question sharding Carpentry 4 08-02-2008 04:56 PM
Some basic question about roofing help! motd0iyeuem Roofing/Siding 6 12-19-2005 07:15 AM
