2 Ballast To 1 Ballast For 4 Lamps - Electrical - DIY Chatroom Home Improvement Forum
Old 07-11-2011, 08:32 PM   #1
HJR
2 ballast to 1 ballast for 4 lamps
I am replacing 2 ballasts in an old 4 tube fixture with a single ballast (as per our local elect. supply store). I have connected all the blue wires to blue, red to red and yellow to yellow. The black and white are connected to line. Only two of the tubes light. I have switched the pairs of red/blue/yellow but this does not help. I can not remove the fixture from the ceiling to look at the wiring to the sockets. Any suggestions?
HJR is offline   Reply With Quote
Old 07-11-2011, 08:39 PM   #2
Electrical Contractor
kbsparky's Avatar
How many red, blue and yellow wires are there on the new ballast?
How many red, blue, and yellow wires are present in the fixture?
Exactly what did you connect where?
-KB
Old 07-11-2011, 08:46 PM   #3
Electrician
SD515's Avatar
Rewards Points: 504
Compare the diagram on the old ballast to the diagram on the new ballast. You may be able to use the current wiring in the fixture without having to remove the lampholders (sockets), maybe not. You might have to re-wire the lampholders some.
Don’t be overly concern on what the colors are of the lampholder wires, (ie red to red, blue to blue), just which is hooked to what.
Kyle
Old 07-11-2011, 08:52 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
The fixture needs to be wired according to the diagram on the ballast, NOT the color of the ballasts and socket wires. The new ballast is wired completely different.
The Following User Says Thank You to Speedy Petey For This Useful Post:
DangerMouse (07-11-2011)
Old 07-11-2011, 10:04 PM   #5
HJR
The 2 old ballasts each had a single blue, red, yellow, white, black. The new ballast has a single white and black a 2 each red, yellow, black.
Old 07-11-2011, 10:16 PM   #6
joed's Avatar
Rewards Points: 13,728
The white and black are the only two wires that will match.
For the others you need to refer to the drawing on the ballast. The colours might or might not match.
The Following User Says Thank You to joed For This Useful Post:
Speedy Petey (07-12-2011)
Old 07-11-2011, 10:55 PM   #7
" Euro " electrician
frenchelectrican's Avatar
I found one very simple diagram but note on the drawing the plug is actually incomming supply.
This drawing is for instat start parallel connection if you have rapid start ballast let us know there is a diffrent drawing I will post it later if you have the rapid start ballast but majorty of 4 lampers I genrally see are wired for instat start but there are few rapid start in 4 lampers as well that is not included in here as you descrbing the numbers of conductors so I know it is instat start.
Merci,
Marc
Old 07-12-2011, 06:24 AM   #8
Once again, this DOES NOT matter.
Please see post #4, then #6 & #7
frenchelectrican (07-12-2011)
T12 ballast to T8 c.bustle Electrical 5 07-10-2011 10:33 AM
4 Lamp 2 Ballast Fixture jhalst828 Electrical 2 06-25-2011 09:27 AM
wiring a ballast from t12 to t8 family Electrical 3 05-17-2011 08:57 AM
No ballast in 48 inch fluorescent fixture. Timster Electrical 16 06-10-2010 04:02 AM
T8 vs. T12 Ballasts capt2 Electrical 22 05-15-2010 03:25 AM
