2 Amp Circuit What Wire? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-04-2008, 08:19 PM   #1
Rewards Points: 150
2 amp circuit what wire?
i want to run a dedicated 20amp circiut for a window air condition, is 12 gauge wire ok to run? and for the outlet can i use a 20amp 125volt or do i need a 20 amp 120 volt?
drewhart is offline   Reply With Quote
Old 12-04-2008, 08:31 PM   #2
12 ga = 20 amp.
110, 115, 118, 120, are all the same thing. I don't know if I've ever seen something marked 125 volt.
220/221 is offline   Reply With Quote
Old 12-04-2008, 08:39 PM   #3
Rewards Points: 150
the outlets at hd for rated 20 amp said 125v on them. the 15amp ones said 15a/120v and the 20 amp ones say 20a/125v.
Old 12-04-2008, 08:48 PM   #4
120 125 volts, they don't matter.
rgsgww is offline   Reply With Quote
Old 12-04-2008, 09:27 PM   #5
120, 125. Whatever it takes.
jerryh3 is offline   Reply With Quote
Old 12-05-2008, 06:32 AM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,874
Receptacles are rated 125V or 250V; not 120, 240 or some other number.
Commercial devices can be higher but that has no bearing here.
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 08:59 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
ground wire in mc circuit woodturner Electrical 10 08-07-2008 12:34 PM
Can you wire a 3-way circuit with 2 wire + ground mnyman2003 Electrical 8 12-04-2007 09:23 AM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 09:09 PM
