2 - 900w Tansformers On A 15A Circuit? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-20-2008, 10:24 AM   #16
tonyBagadonuts's Avatar
Rewards Points: 29
I have not putchased yet, but it does have 3 connections. My runs will be fairly short (about 100' each) and I will be very close to max watts
tonyBagadonuts is offline   Reply With Quote
Old 07-20-2008, 03:45 PM   #17
" Euro " electrician
frenchelectrican's Avatar
Ahh ok but keep in your mind you will have to use #12 LV cable size., Don't use the #14 or smaller size they will cause alot of issue with voltage drop.
Merci,Marc
Old 07-20-2008, 04:27 PM   #18
Electrician
Merci,Marc
And dont do straight runs, do "T" style runs, or what I like to do is full circle runs, so the beginning and the end of the run tie into the transformer... Helps greatly with voltage drop. Just dont mess up the polarity.
chris75 is offline   Reply With Quote
Old 07-20-2008, 05:55 PM   #19
Rewards Points: 29
Thanks.. All good ideas............ I had already bought the #12 and I have some #10 if I have tio make any longer runs, the circle idea sounds good
Old 07-20-2008, 07:15 PM   #20
Electrician
One other thing, stay away from those plastic splice kits, I find they have a terrible failure rate, wire nut every splice with DB wirenuts for a trouble free installation.
Need a wiring diagram Mooreski Electrical 47 02-01-2015 03:07 PM
Problem with circuit breaker. HELP! spartanic Electrical 2 10-28-2007 03:09 PM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 08:09 PM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 10:05 PM
